1994 3.8 LX Head Gasket Symptoms
Bobs21x
N. Texas
94 LX 3.8
I replaced the water pump last Fall and just added a new radiator this month. The upper radiator hose stays tight with pressure for days after driving it.
I still can't keep coolant in the radiator, and it is beginning to overheat. The thing is' there's not a drop on the ground.
Yesterday, I drove it about 65 miles to a friend's house and it overheated, and the light came on. I pulled over and let it cool down and noticed a ton of water belching out of my overflow bottle. I added nearly two gallons to it after this episode.
Does anyone know if these cars had different rotation water pumps? I am fearing that it could be the head gasket or something else catastrophic. My oil pressure is good and is normal color on the diptstick.
Did you fill through the vent tube on the intake manifold? If you don't get all of the air out of the cooling system it can trap air inside which will cause it to overheat.
I burped it through the vent but did not fill it through the vent tube. I raised the front end and cracked the vent until the air was gone, or so I thought. I will triple check everything once I get it home. I left the car at my friends in fear of it overheating at night on the 65 mile journey home. The new radiator did not have a fill hole, so I added an inline fill and cap. in the upper radiator hose.
Every time I thought I was having a hg problem, it was the oil filter adapter gasket, but that may only be the 4.6 cars.
Head gaskets can fail in a few different ways. One is a leak between the cooling system and the crankcase. In that case, your engine oil will start to look like chocolate milk. Another way is it can leak between the cooling system and the combustion chamber, which based on your description of the hose staying pressurized, I suspect that is what you have going on. Get yourself one of these. It is easy to use and will tell you quickly whether you have combustion gases in the cooling system, which on a 3.8 would almost definitely be a bad head gasket.
Lastly, I seen no water or wetness from the exhaust.
I will get a better diagnosis when I get it home. I was just getting it ready to be my daily driver when this all went South.
Thanks for the link MadMikeyL 👍
Are the head gaskets original? The link MadMikey posted is good for diagnosis. I would also check the condition of the oil for the aforementioned milkshake. When the head gaskets went on my old '92 3.8 it ran fine and the only obvious sign something was wrong was it was using coolant. One cylinder had coolant pouring out of it when I pulled the plugs.
Good news is head gaskets are pretty simple on the 3.8 N/A and once you have it done the engine should be just about bullet proof.
I found a complete Fel-pro kit (HS 8857 PT-6) for $78.
Does this kit compare to what you folks have used before that did the HG repair on a 3.8? I think it has the good gaskets in it.
That’s a good kit, but not a good price. That same kit is on Rockauto right now for $31. Also you will need new head bolts as they are one-time use.
I saw that on Rock Aito after I posted. lol
I was also looking at the Mahle Fasteners. Any preference there?
I searched originally for a Flat Out brand head gaskets since our cars seem to like pushing out the head gaskets
Those are standard composite gaskets .. the good ones are the MLS ( multi layered steel ); but you need to resurface the heads and the block to the correct Rough Average. You'll be fine with standard gaskets, and check the heads for flatness .. it's cheap insurance to have them resurfaced either way
For sure getting the heads resurfaced and checked out.
Which fastener at Rock Auto of this list?
None of the above
I couldn’t find any when I searched their web site. The Chevy ones you added will work for me? That’s information I did not have! lol
I 100% agree on ARP.
I would go with the Mahle head bolts. I’ve never heard of the other two brands. The ARP head studs are nice, but likely overkill for a 3.8NA. If you do go with ARP, order a set for a Chevy 2.8 V6. They fit supposedly better than the one specifically for the 3.8, and were also cheaper last time I checked. I have them on my 90 XR7, and they hold up just fine with 18psi.
Back in the day they didn't have the MLS gaskets so I always just used the standard Perma-Torque Fel-Pro gaskets without any issue. You should at the very least check for flatness, but I just usually have the heads resurfaced regardless. I'm surprised Fel-Pro doesn't still make head bolts for these.
Nick mentioned the Cometic MLS gaskets, but that was on my 4.6 build.
I opted for the ARP route and bought suggested part #233-4003. Is this the correct fastener for my 3.8? It’s a stud kit with no bolts. It has washers and nuts. I understand it’s the Chevy kit and all, I’m just asking to be sure 👍
Yes. Arp studs are not 'use once' either. If you need to replace the gasket in the future, it's easier/cheaper too.
I would suggest getting the head resurfaced for the mls gasket, while you're there.
I would skip the MLS gaskets for a stock car. Technically you are supposed to machine not only the heads, but the block to use those gaskets. Also they are simply overkill for a 3.8NA. On a boosted application is one thing because they can’t fail due to detonation like a stock one can, but for a naturally aspirated daily driver, the stock style felpro ones are more than adequate. Heck, I still have stock felpro ones on my 90XR7, along with those same Chevy 2.8 ARP studs, and they are holding up just fine to tens of thousands of miles of hooning at 18psi of boost.
Are there any other bolt kits I should consider?
Can I reuse my rod bolts if they’re visually Ok?
I am bringing it home today or tomorrow and start the project.
Rod bolts? I thought you are just doing a head gasket. Are you doing a full rebuild? Cause you don’t touch the rods for head gaskets. If it is a head gasket job, you should be able to reuse all the bolts except the head bolts.
You’re right! I was overthinking things looking at ARP list of goodies 🤦‍♂️
Thanks again
After purchasing the ARP kit part #233-4003, I noticed these are studs and I believe mine utilized bolts. Is this correct?
Thanks again. I was just watching a few videos when I noticed this variance. I am about to start tearing it down.
Yes, the ARP kit is studs. The studs are better and reusable. Just put the heads back as normal, thread the studs until they bottom out, then put the washer and nut on with some of the lube they give you and torque as normal.
No loc-rite or thread sealer to be used?
Thanks again 🇺🇸
Correct. Just clean the threads in the block and put the studs in dry. In theory you should be able to thread them all the way in by hand, but I always wind up needing to use the Allen head in the top to get them all to the bottom. Don’t torque them into the block though, just barely snug, then the nut gets the lube and gets torqued.
Started tearing the old girl down today finally.
Do I need to clock TDC on distributor or anything?
It looks like the distributor can stay in for this head gasket job?. So far, it appears to go through the timing chain cover?
Thanks again 👍
