94-97 lower DIN Autometer gauge package
XR7-4.6
Staff member
Roselle, IL
    1994 Cougar XR7 DOHC TR3650
    Hey guys I’m giving you first crack at this, I put this together in the summer but it doesn’t really fit my vision for the interior so out it goes. It’s all electric short sweep Oil, coolant and Volts Sport Comp IIs. The bezel is custom made anodized aluminum and the wiring is all custom made; it gets get power from the starter terminal, ground to the motor mount and connects to the oil and water temp senders from behind and the relay just needs any hot in run connection (I used one off the cluster). It passes through the firewall grommet(if you have a 94-95 ABS car it will need to be punched through the side of that harnesses grommet)
    The wiring is fused and has auxiliary terminals for other accessories like in my case a wideband and subwoofer power, I made it as neat as you can get.
    $400 firm. The gauges alone are worth as much and it’s as plug and play as you can get so I think it’s fair, they were only used in my for about 250 miles last summer/fall
    Not anything that would fit my walnut vision either, but beautifully assembled and very neatly installed! Best of luck with the sale!
    If I was the gauges type of guy, I think I would install them in the upper position and relocate the climate control to the bottom. Put them into your line of sight.
