- Oct 2, 2023
- New Mexico
One of the members here mentioned that owning a Cougar / T-Bird is like playing wackaball, I can relate.
The volt meter started doing the metronome thing, then the inside lights are dancing to the volt meter and more is coming. I checked voltages at the battery;
1. Key off - 12.5 volts
2. Engine running, high idle - 15 volts
3. Engine running 750 rpm - 15 volts
My thought is the regulator is bad since the alternator is putting out 15 volts.
Alternator - $100
Regulator - $20
Suggestions? Comments? The alternator does not have that many miles on it.
What's weird is I hear a ticking when I shut off the engine and this has been going on for some time. I related it to metal cooling down after the engine gets hot. But it was doing it today so I pulled the negative terminal and the ticking stopped. The sound was coming from the upper center of the engine. My first thought is the injector is stuck on due to unregulated voltage.
Alternator - $100
Regulator - $20
