- Oct 2, 2023
- New Mexico
Driving home this morning, the Cougar just died. Coasted into a closed gas station and tried to start the car. Cranks, but no start. Had it towed home and ran codes. Code 564 Fan Control (FC) CKT Fault. No issues up till now except the Check Engine light would come on once in a while and go off.
From what I can find, the Constant Control Relay Module (CCRM) is at fault. I think I replaced this a few years ago.
Any suggestions other than replacing the CCRM? Fan does run under KOEO test, both low and high then brings up the code 564.
Thanks.
Thanks.
