Fuel level issue
bowez
2nd Gear Poster
Nashville
93 SC
My fuel gauge went from 1/2 to Full while driving Saturday. I know with how much I've drive it should be 1/4 to less, any input/ideas the most likely issue? Time to drop the tank?
After restarting I did watch the gauge go from 7/8 full to Full.
Float maybe getting stuck/ issues with fuel sending unit? Would be my first assumption but idk if these cars have a float or if its all electronic. Ive never even dropped a tank on one of these so take my opinion with a grain of salt.
I've never personally had to futz with it, but I'd start by reflowing the solder joints. IIRC when it goes bad it opens up and goes full ground, which is a full tank on the gauge.
I'm sure I'm wrong or missing something important though, so wait until Matt or Greg or someone who is sure chimes in. :)
I can try to scan the factory fuel gauge troubleshooting flowchart, but most of it requires manipulating the float. I had an '89 SC in the shop recently that always read full. I swapped in a different cluster (with anti-slosh module) and got the same thing. Wound up having to replace the sending unit in the tank.
Check the cluster as well. When I got mine forever ago the gauge was stuck on full. There is a chip on the right side of the cluster. If it slides out some and looses connection it will go to full. I slide it back in and never had an issue since. That was over 15 years ago.
Right. That is the anti-slosh module Terminator mentioned above. Hopefully that is it, because it is a lot easier than the fuel sending unit.
Hmm. I need to investigate. My gauge is all over the place. Generally hangs between 3/4 and full until it gets low then it "may" drop to 1/4 or less momentarily and shoot back to full. I did run it out 6 months ago so now I watch my trip odometer and track my fuel qty. I've got years of consistent mileage of 22-24 mpg on my daily commute. What annoys me is pre-paying and guessing how much it will hold and it clicking fill $6.00 left. Most times it goes back on card but have to go in to be sure.
Brandon nailed it. The anti-slosh module is on the back of the cluster. While you have it out, you can short the 20 ohm resistor, so you can use a real oil pressure sender. Ours is a switch, and the 20 ohm sets the reading.
After you short it a ps60 sender will make it read real pressure. It's huge compared to the switch; I used a npt 90 to make it fit.
If you want to check the tank sensor, You'll have to use the evtm to find the wire.
Well, thank looks like the week I'll pull the cluster. I already have a Autometer Oil Gauge in the A-pillar, and have all the EVTMs... Got to to the Radiator fan first though (decided to got with weather-pak connector 630).
I'd find a connector you can get to, and ohm the tank sender, to see if it's grounded.
