- Oct 2, 2023
- New Mexico
As you may know, or not, I have a 137/173 codes / bank 1 & 2 running rich (only 2 cats on a 94). I have no idiot lights, no rough idle and it runs great, but I noticed in my notes that I got the codes after replacing the regulator with a new from RockAuto last year. The regulator is spec'd for for 94-97 Ford, Lincoln and Mercury 3.8l and 4.6l. I cannot find the PSI specs on the regulator from any of the vendors the manufacture. I noticed that with several of the regulators' on RockAuto, they have various PSI ratings up to and over 50 psi, which I have learned is typical with RO parts. The current pressure running at idle is 38 and "giving it the onions" (strange phrase) it is around 40 psi.
Is there a way to test the regulator to see if the pressure spikes, drops or basically is part of the problem? Before I start part swapping, I wanted to see if there is a way to tell if the regulator is working correctly (using a pressure gauge or other means) and allowing more fuel than needed causing the rich codes. I have pulled vacuum the line several times when pulling the upper intake and never say gas from the regulator or vacuum line, so I don't think its leaking.
I read a few articles about bad regulators, but their issues where rough idle, idiot light was on, etc... I have none of those issues suggested.
