- Oct 2, 2023
- New Mexico
I recieved my new IAC from RockAuto yesterday and took a few minutes to replace it. After it was replaced, I tested how it worked compared to the other two I have been using. The weird idle pattern is gone. The idle now starts at 1500 and slowly goes down to 700/750. No 2500 rpm when cold, hang for 5 seconds then drop to normal. When I put it in reverse to back out, the car would die. That is gone too. So both the OEM junk yard and RockAuto (old purchase) IAC's where crap and the cause of many of my issues.
If you don't believe using the wrong cleaning fluid on an IAC will ruin it, try it sometime. I hope your IAC won't go to shitz like mine did. That was the RockAuto one that basically broke after using brake cleaner to clean it out.
I used a new gasket and torqued the bolts to spec on the new IAC. Torque is 7 ft/lbs on the bolts.
