In the process of changing my spark plugs (SC) I am keeping an eye out for possible shorts that could be the cause of my airbag code 51. I've found this (see Pic below).
What was there originally was the regular round plastic wire protector wrapped with electrical tape. Showing through were cracks with shiny foil shielding showing through. After removing the tape on this section, the plastic protector crumbled away revealing some foil shielding, a bare stranded wire underneath the foil that wraps around the two insulated wires (blue and white). The harness on either side of the section I removed seems fairly sound.
Is this a repair or is this a factory shielded portion of the harness. This harness comes out of the same harness the coil is plugged in to. I believe the termination on this end goes to the AC compressor.
If this is the factory ford method, I can easily repair it. If it's somebody else's repair, I'm not sure it's correct.
Any facts or opinions you knowledgable folks would like to share?
Also, I'm not sure if an airbag code 51 refers to a short only in the airbag wiring or any short overall. The only way the "shield" shown in the pic could cause ANY short would be if the bare wire got hot enough to melt in to the insulation on the blue or white wires. Possible? Maybe, but I don't thinks it's all too probable.
Chime in please....
Chime in please....
