MIG Welding
White Lincoln
Seasoned Veteran Poster
New Mexico
As a newbie with MIG welding, I had a question or two.
When welding with my cheap little Harbor Freight welder, do I use steel wire to weld exhaust or can I use aluminum wire? I didn't even think about it when I bought it. I just told the guy, "I need to weld with a MIG and anything but copper" and he handed me an aluminum reel.
My weld is non-existent yet as I have never tried MiG welding. I just have blobs of metal all over the weld area and nothing on the actual stuff I am welding (laughing my ass off as I kept expecting something different). I did oxy/ acetylene years back, but this is different.
Never mind. It's obvious the guy that helped me at the store did not know anything about welding. Off to get some mild steel wire.
If you're using a cheap HF welder, chances are it's flux core only. If you don't have a tank connected to it (like C25), it's not MIG. You'll need flux core wire.
Yep, no gas, flux core welder needs steel wire (for steel) and flux core wire. Expensive! Learning as I go.
Just got back from Harbor Freight with the right wire this time. they have a big chart on the wall above the wire that tells you what kind of wire to get. That helped.
I’m no welder but one of the biggest issues I’m aware of with cheaper flux core welders is blowing right through thin steel, which makes them pretty useless for body and exhaust work.
If you are just starting to learn, I strongly recommend getting an actual MIG welder with a gas tank instead of the flux core. Flux core is fine in a pinch, but the welds are always messy with lots of slag and spatter, and it is hard to control when welding thinner metal. If you already know how to weld, a flux core is better than nothing, but if you are trying to learn, you’ll likely get discouraged by the flux core.
Frack... I had photos! I really had the photos of my first welds!!! But when I went to turn on my PC, nothing. The drive took a dump. Luckily, I kept my Win 10 drive and plugged that in. But my photos are not understood by windows 10 (HEIC) so I am having to download VLC to open them and put them in here.
Thanks Zep. I looked at it this way: I could pay someone to weld my joints on my exhaust, pay someone to make me a hitch and do some other stuff all for the huge unjustified price of hundreds of dollars. F-it... it's time to man up, buy a beginners welder and equipment and I will not only have fixed my stuff, I will have learned a trade that is invaluable when the wife wants a new steel coffee table with a glass top for the porch... :p
And Mr. Mikey... I contemplated what to do for some time. I have been wanting to get a small oxy / acetylene welder and tanks and pic up where I left off, but the damn price was just nuts. I would rather use gas, it is clean and strong unlike MiG that is messy and strong, for what its worth.
Got new pics:
1st attempt, 2nd attempt and the last attempt before calling it a night. You can see the bead gets smaller, less crap and a better aim.
I did need to spend time reading the manual, adjusting my head gear and learning to hit the spot and not stay on it too long. The next welds should have better penetration. I did grind down the edges to a 45 angle (to create a trough between the two pieces) and polished the steel area to make sure it was clean.
Out to practice some more.
What you have is not a MIG welder. What you have is a flux core welder. They are different. They weld differently. A properly set up MIG can make nice welds, not TIG level stacking dimes, but nice enough. Flux core will never look nice. I know they are significantly more expensive to buy, but the results are going to be night and day, and it will be much easier to learn on and get used to.
Thanks guys. From the videos I have watched, I thought Flex core (e-hem) seams look nice. I did some more practice welding on pipes today and am getting a little better. I do have some issues with balance and technique, but that gets better with practice. I have a lot of practice pipe to use, and the tools to make it all happen: grinder, polisher and cutter. I think as I practice more, the welds are going to come out nice.
We do have MiG welding classes (Flux Core?) at our local Central New Mexico Community College (which I worked at for 10 years) and unless you are going for a degree, it is like $90. But I don't think I need to go that far, it is not hard to weld exhuast and from what I have read, Flux Core is the way to go to seal up those pesky joints.
After working on some pipe again, I decided it was time to make something to HOLD the pipe in place instead of using my vise.
I welded two pieces of scrap metal at a 45 deg, then put a flat bar under the V with a long flat peice. It can be clamped down if needed. I noticed two things, I was getting a stream of tiny, tiny coins and it was penetrating too. But I still have slow and steady movement as an issue. I think I need thicker wire to make larger weld beads.
I’m actually fairly impressed you didn’t get much if any blow through I can see. I’ve been toying with getting a cheap flux core just to tack an exhaust together now that I have to redo the front half and pay someone to fully weld it without bringing them the car and having them cut and shape all the pipe.
I’d get a MIG but I just don’t have the space for it and the tanks for the minimal use I’d get out of it, let alone the cost
I need to get new regulator and hoses for the cutting torch I have, and get the tanks refilled or replaced, and learn to use the stick welder I have. I'll buy a book and go from there. I've learned a lot that way. One of my great nephews buddies does aluminum, and he said he'd weld up my manifold if I fix an amp for him. Amps are easy. Tape decks, not so much. Took me 4 hours the other night to put on a belt,lol.
