In the long list of plausible “what-if”s with the MN12 platform - what if there was a SVT, what if there was a 1998 model etc - this piece of trivia might be well in the basement, but it is the most obtainable to you for literally $20!
I am of course talking about a LED backlit mirrror switch, something Ford fully engineered(in which I’ll go into detail below) but never actually implemented, on MN12s or other cars of the 90s-00s that used a similar switch. Here I will show you the evidence of the intended function as well as show you exactly how to finish the job yourself.
Here is a stone stock 94-97 mirror switch
Many many years ago I was sitting in traffic and fidgeting with things as one with ADHD does and wound up pulling the switch right off, and was relatively surprised to see I hadn’t broken it but revealed a translucent inner body to it, and then found the white outer switch arrows were translucent themselves
So what is one to do with such a revelation? Well take it apart of course! See what I see?
An 8 pin connector with just 7 pins
Must dig further!
Lots of dielectric snot! Eew!!!!
Let’s clean that up a bit shall we?
Now things get a little more interesting. You can spy a few unused holes in the circuit board… not only that, flip it around and reveal a plastic spacer piece with a curious rectangular hole…
Given the placement of such things you might deduce that these were intended to house a 3mm LED a load resistor and an extra pin powered by the ignition? Well let’s put that theory to test
Must dig further!
