- Oct 2, 2023
- New Mexico
SOB!
Took the Cougar out for a spin this morning after fixing he seat belt to see if I could actually make it burn some rubber. As I am driving along, I look down and I noticed my odometer reset had not changed from 0000 since the last time I reset it. Then I notice my main odometer is not changing either! SOB! "If it's not one thing..."
So I tore my steering wheel and dash assembly out to get to the display assembly. I made sure I did not have one of the two cables partially disconnected. I start tearing into the display assembly and pull the speedometer out. I start tearing it apart, afraid I was dang well going to brake or scar something bad. I got it all apart and I can't see any gears with issues. I pull off the drive gear for the speedometer and sure enough, ONE GEAR IS BROKE OFF, laying there next where it should be.
It's not the part replacement and all the work to get into fix it, its THE COST!!!!! I did find one on Amazon for $32, about the cheapest I can find without getting into risky vendors from somewhere I can't spell and it be made of really cheap plastic.
The red arrow is pointing to the broken gear sitting next to the gear.
BTW: I forgot to mention that the gear will be here by 8 am tomorrow. Knowing Amazon, that will be 7 pm tomorrow night. Sometimes I think our delivery guy drops off our packages last before hitting the bars for the night.
