Oil in Coolant
bowez
Nashville
93 SC
Looks like my daughter's first car will be a 97 4.6 Tbird. Currently it has oil in coolant, buying as if the head gasket is failed (drives fine though). I'm personally leaning toward filter adapter gasket, is this a valid assumption or what else could I be looking at? Haven't done a compression check nor exhaust gas check. I haven't seen white smoke nor water out the exhaust nor over pressured coolant.
