Rooftop solar
theterminator93
Staff member
North Ridgeville, OH
    Achieved a personal goal/milestone - got our mortgage paid off in 88 months. Now it's time to start figuring out this investing thing, and having some fun. :biggrin:
    For the money we'd have otherwise been dumping onto the mortgage for the remainder of this year, the wife and I agreed to take the plunge and install a rooftop solar array while we can still get the 30% tax credit. The new solar array will be using Tesla inverters. The company had been using Enphase inverters up until recently; my MIL's system uses them and she's had to have someone out to service them half a dozen times in the last year. :rolleyes:
    Our new solar system will be using Tesla inverters. The company was using Enphase up until recently; my MIL's system uses them and she's had to have someone out to service them half a dozen times in the last year. :rolleyes:
    Awesome! Good for you guys! What a great feeling! That's impressive! You guys are super savers!
    So you're getting a Powerwall battery pack? What panels are you going with? I would guess that you're too far north for solar to be cost effective but I've seen solar farms as far north as Green Bay, WI.
    Not familiar with Enphase. I'd be bullish on ADBE sub 300. It currently has a floor of support around 330 or 332.
    For an AI play yeah, there aren't many left that haven't left the station. The other sector that I'd be looking at is Quantum computing. GOOG would be my play on that one. I've also got my eye on D-Wave (QBTS). It came onto my radar just before it took off. It still has a PT of $26 implying about 53% upside. I'm watching this one for a pull back.
    I don't know much about Enphase as a stock but they are the leaders in microinverters (putting one DC->AC converter behind every panel). Here are some thoughts from recently helping a friend spec out a system for SoCal (where SDGE give PG&E a run for their money in scumbaggery and country-leading prices per KWH).
    a) All solar companies are going to hit headwinds because of the cancellation of the the tax credits by EOY 2025.
    b) While microinverters offer resiliency (one microinverter dies and your setup stays operational but with lower power generation) and are better if you some of your roof gets shaded (as each microinverter can automatically adjust to the sun each panel gets), there are some pretty noteworthy drawbacks vs a traditional "string inverter" setup (most typical are two or more strings of panels daisy chained together and feeding into a single central inverter (SolarEdge being the biggest player here):
    - Each microinverter has a max output of 325-384W. This is problematic when the most common panel is 435W. Under peak sun, you end up hitting the cap so your 10x 435W panel system should be generated 4350W but in reality generates 3250-3840W (12-26% less power).
    - The shading issue with centralized inverters can be solved with something called an "optimizer", a small module you put behind each panel. Without optimizers, a string inverter system can only output the power of the most shaded panel in each string of panels.
    - Between this efficiency hit and the cost per microinverter, Enphase systems can be pricier than an equivalent string inverter system.
    - Batteries are required for NEM3 system (where you only get paid wholesale for your surplus power) and any microinverter system with a battery MUST have AC-DC converters (addt'l microinverters) built into the battery packs. This adds significantly to the cost. In comparison, a string inverter system can handle the AC/DC conversion for a battery. Ex: Tesla Powerwalls are AC attached and can run $10K for 13KWH. Enphase's own 5KWH battery runs $3.5K. In comparison a DC attach LG 16KWH battery is as cheap as $2.8K. Sure, the inverters baked in the battery gives you some added resiliency (if one inverter dies, the others can keep operating and give you some/most of your battery capacity) but you are paying for this resiliency. Also, these additional AC/DC conversions (DC from panel -> DC/AC microinverter -> AC/DC converstion to storage and then DC/AC to load) cuts down on overall efficiency (you store 1 KWH, you don't get 1KWH back).
    While I'm not sure I'd invest in ANY solar company in the US right now (other than as a customer), these kind of tradeoffs are worth noting if you are considering Enphases long term growth prospects.
    Thanks, we've been looking forward to this for years but it still doesn't feel quite like it's real. :biggrin:
    My MIL got a battery but we won't be; just rooftop array. The designs haven't been finalized or submitted for permit approval yet but the preliminary workup is for 24 of the new 440W Silfab panels, which should produce an estimated 103% of our average annual grid consumption - even with the PHEV. They should pay for themselves in 9-10 years (at most, given how fast prices are going up it will be less than that).
    I was interested in a battery but when I learned it would have cost us as much as the array all over again, I shelved the concept. Once solid state becomes mainstream (and costs plummet) it might be an add-on; the power here doesn't go out long enough or frequently enough to justify that cost right now though. :)
    Even if you live in a place without blackouts, the biggest reason to install a battery is to use your own surplus generation during peak hours and eliminate that more expensive consumption from the grid.
    If you have net metering 1.0 (one kwh in gets you 1kwh out when you want it) or 2.0 (utility must pay you retail rate for your excess power), the grid is effectively your battery.
    As far as prices going cheaper, my biggest gripe with solar in the US is how much markup there is for installers. I've received quotes of 15K plus to install a smaller 10kwh battery than the 16kwh one I found online that is confirmed to work with my existing inverter. Absolutely nuts
    PS congrats on paying off your house. I've got decades left on my place :)
    The other reason for using a battery is to use your own energy after the sun goes down at night or on cloudy days.
    Yeah, our utility uses the net metering model. So the grid effectively becomes our battery, and we don't get billed for any grid draw as long as we produce more than we use over the course of each billing period. When we produce more we get a bill credit that carries over from month-to-month. I'm curious to see what production looks like on cloudy/rainy/indirect sun conditions. A friend showed me his (old, much smaller) array producing something like 1 kW on a dark, overcast day. Something I liked with the panels I'm getting is "improved low light performance" and a guarantee of no more than 10% performance degradation over the 30Y life of the panels.
    Based on estimated production we will be generating bill credits from March through October, which we'd then use up from November through February. So aside from the $4/mo "customer charge" our electric bill will go away. Over 30 years the net savings, less the initial investment, would be something like $50k.
    FWIW the pre-tax credit price of our array is going to be like $26k. If they were including a battery the cost would have gone up to about $45k. I just can't justify that. :eek:
    Our new solar array will be using Tesla inverters. The company had been using Enphase inverters up until recently; my MIL's system uses them and she's had to have someone out to service them half a dozen times in the last year. :rolleyes:
    Congrats on the mortgage. Had planned to pay mine off this year until I lost my job in 2019. 4 months unemployed and a 30% pay cut for 2.5 years afterwards, I'm now on pace for 9 more years and assisting with college for 3 along the way.
    As for solar, no net-metering in my area, so there is no financial incentive to install despite my house orientation being optimal--south facing 42'x14' garage roof with no obstructed view of the sky.
    Q: How large is your array in KW for $26K?
    I paid right around $4.16-4.22/watt for my two setups in 2023 (home and rental). That was excessive when a good deal would ahve been more like sub $3/watt but it was necessary because there was a hard deadline in CA to qualify for NEM2.0 (retail pmt for excess power) and this was an installer that could get the paperwork done in time.
    $27K for 6.4KW (16 panels) = pitched roof
    $30K for 7.2KW (18 panels) = flat roof
    As far as summer/winter generation difference (both arrays point straight south):
    - Production on the 7.2KW array is about 1.2-1.38MWh during the summer months and 500-640MWh during the winters here in SF. These panels have no shading b/c they are higher up
    - Production on the 6.4KW array is about 1-1.17MWh in the summer and 400-500MWh in the winter.
    Therefore, I see about 50% net production in the winter vs summer.
    Now that you have (or will soon have) solar, you might also want to consider what else you can take advantage of before all the tax credits go away
    1) Window efficiency improvements
    2) Heatpump water heater
    3) Heatpump HVAC
    Electricity wise, the single best thing I did with my home was swap from a gas to heatpump water heater. In addition to getting all sorts of tax credits and rebates from the utility, the heatpump water heater dropped my gas consumption by ~40%/mo (we don't need very much heat in SF). The trickiest part of going with a HPWH was a) the necessity of adding a drain for the condensation and b) the necessity of adding 220V power to feed the heatpump. I've read now that there are 120V HPWHs on the market now so that would be even easier. To get the most efficiency out of my unit, I also added a mixing valve after the HPWH so I just heat the water in-tank to 150F and then mix it with cold water (mechanical valve) to a more usable 130F. HPWH draws 400W when running (80KWH/mo for 3ppl).
    My next car is very likely to be an EV, if not a PHEV.
    -g
    If you have no net-metering, your incentive for a solar+battery setup will be your cost per KWH. California approved something like 6 price hikes in 2024 alone for PG&E so I'm now paying >60c per KWH from 4PM-9PM. The utilities are truly scumbags here in CA. I think my breakeven will be in <5 years, and it definitely shortened because of all the rate hikes.
    Electricity in St. Louis is way cheaper than that. We might still be in single digits for cost/KWH. I'll try to remember to check in the morning.
    3) Heatpump HVAC
    -g
    Lot of stuff I've thought about in here.
    The array as quoted is 10.56 kW - 24x 440W panels, and the pre-incentive price is $25,749. They also quoted $22,977 for a 9.84 kW system using older 410W panels they had an excess of, but I opted for the most efficient panels available due to a better long-term ROI as well as a better panel warranty. So that works out to $2.44/W before the 30% tax credit.
    We live in an HOA that until recently had bylaws that outright prohibited solar. The state passed a law during the pandemic that made it harder for HOAs to do that, so the bylaws were revised that made it possible for us - as long as all panels are located on the rear roof only. I hadn't originally planned to take the plunge on solar until our life plans changed when we learned that we are to expect a daughter in February. As a result the funds I had saved up for our next international vacation were freed up, then I learned the HOA didn't prohibit solar after all, thought about the tax credit... and here I am.
    Our house is west-northwest facing, so the back roof is aligned to about 100° ESE. We have a relatively tall 10/12 pitch 2-storey roof with no nearby tall trees, so it will get direct sunlight from about 1 hour after sunrise until about 4 in the afternoon.
    I ran some numbers through NREL's PVWatts calculator to see how much I'd produce with the panels facing ESE (vs the ideal S) and independently came up with almost exactly the same production numbers the installers provided me. It looks like I'll make about 1.05 MWh each year - if the panels were installed facing true south it looks like I'd be making closer to 1.3 MWh. Our south-facing roof area is much smaller than the roof area on the east side of the house though, so it is what it is. :zdunno:
    My MIL used the same company I am using but 2 years ago they were installing 400W panels. She showed me her generation on a sunny day a couple weeks ago and the panels she had on the E side and S side of the roof each had generated about 1.9 kWh over the course of a day. If I do the math, I can expect good production. :)
    Looking at winter vs. summer production estimates what I'm seeing is, using peak July production of about 45 kWh/day as 100%, December production drops down to about 13 kWh/day or roughly 30%. Our winters are quite cloudy, and it shows in the production estimates.
    Regarding electric appliances, we upgraded our HVAC several years ago - the same year the incentives became available, actually. I had intended to upgrade our old 13 SEER A/C and had been putting money away for it, when we learned the furnace (original to the 2008 construction) was pumping out off-the-meter levels of CO due to cooked secondary burners. So we bit the bullet and upgraded everything with the most efficient models offered for our capacity (120K BTU furnace and 5 ton A/C). We ended up with a 21 SEER A/C and 11 HSPF heat pump along with a 98.5% efficient furnace. Then about two years after that, the original water heater started leaking so I replaced it with what I could get off-the-shelf at a local Home Depot. Before that happened though I was seriously considering a heat pump water heater, but at the time the 120V models weren't great performers, were disproportionally expensive compared to the gas heaters, and none were in stock. :rolleyes:
    Natural gas vs. electric pricing here has remained pretty stable until recently - most of the time gas is between .45-.65/thm and electricity is about .13-.14/kWh - though electricity has gone up about 30% over the last year or two and is closer to .18/kWh for anyone not rate shopping. Given how cheap gas is, it's never cheaper for me to run the heat pump instead of the furnace. With the solar array going in though, that will probably change things, especially if I generate an excess credit each year which I would could "use up" by running the heat pump more often. I'm waiting to hear if they think they can get more than 24 panels up on the roof. I only foresee us using more electricity in the future, so having the extra capacity installed now won't leave any regrets.
    I can adjust the setpoints for when the heat pump runs vs. the furnace, and I have an Excel sheet with the performance efficiency matrix of the heat pump built-in to help me determine what temperature it's more cost efficient for me to run the heat pump or furnace at. I plug in the cost/therm of natural gas, the price/kWh for electric and it spits out the temperatures at which it becomes cheaper for me to use the heat pump.
    This is the business end of that sheet which shows the current prices I'm paying and, correspondingly, the fact that it's not better for me to run the heat pump at all with these gas prices. All the same, I usually let the heat pump run when outdoor temps exceed 50 degrees, even though it's more expensive. It just feels a little more comfortable for some reason.
    1) noone has ever told themselves "man, I wish I had bought fewer panels". At least in CA, the utility can cap how much you can add. The only exception is that some systems can be configured for non-export, so they curtail their production after trh batteries are full
    2) your price is good. I suspect that reflects lower demand given how cheap your electricity is; the labor markup is IMO pretty fair.
    Q: do you live in a state with hail/crazy weather? If so, 1) check to make sure your insurance covers the panels or if an adder is needed and 2) see if there's a difference between the panels in terms of impact resistance
    3) how easy is it for animals to get to your roof? It may be worth a few bucks more for critter guard to be installed to protect your wires.
    I have now gone down the solar rabbit hole. I did learn the Missouri passed a law that required utility providers to allow net metering for systems less than 10 kW. Ameren is my local provider, and they don't advertise (or at least didn't use to) anything.
    Pretty sure I can't swing anything this year due to my oldest starting college, but I am going to see about getting a couple of estimates.
    As for current electrical rates, winter rate is $0.0919/kWh. Summer rate is $0.1524/kWh. So still cheap compared to many places in the US.
    Hail is a big concern here. Many houses near me with complete roof and siding replacements due to a storms on 3/14/25 and another one on 5/16/25.
    We don't get much severe weather - small (pea-sized) hail once every few years and there's an occasional weak (EF0 or EF1) tornado that rips through the general area. The worst weather we get tends to be in winter with regards to snow and/or ice. The panels are rated for 1" hail at typical terminal velocities and pressures +.8 to -.6 PSI, which (if I do the math right) equates to a minimum of 180 MPH or an EF4, or about 2' of snow cover.
    Fortunately the only critters that can get on our roof are birds. There are no lines, trees or other pathways for squirrels or raccoons to get up there. Based on the install my MIL got, they put all the wires into PVC conduit to keep them protected from the jaws of any deviant beasts.
    Kurt, I started off with a website called Energy Sage. They're clearly a for-profit and they get their cut from the installer you select (if you go down that path) but it was a nice way to see the installers in my area. I was able to get in touch with several to speak to them and make sure I was getting the most competent company.
    So I have an appointment with a solar installation company to start investing further. The 1st company I called is booked through the end of the year, so I had to check elsewhere. Just starting the conversation for now.
