Somebody check my numbers on these winter wheels/suggestions for other wheels.
KevinVarnes
Grand Rapids, MI
Trying to find a good (and by good I mean cheap) set of 17" wheels for winter snow tires. I need 17"s because the car will eventually have Cobra brakes. Looking for something relatively cheap. I don't really mind black steelies, but I am open to other OEM alloy wheels that don't look too terribly hideous. I stumbled across the Maverick/Bronco Sport wheel specs and I think they should be about as close to perfect as you can get. Offset looks good, obviously 5x108, and the center bore is the same as MN12, but somebody check me in case I'm missing something.
Size: 17x7" or 18x7"
Width: 7" width
Offset: +37.5 mm
Bolt Pattern: 5x108
Center Bore: 63.4
Thread Size: M14 x 1.5 lug nuts
Note: these are the same specs as the Bronco Sport wheels
Let me know if you have any other suggestions for winter wheels that will fit without spacers/adapters/etc. that are plentiful and had for cheap.
Pretty sure that should work.
Like, the offset is within spec for our cars, should work.
There are some Jaguar wheels that fit, of I recall correctly. Not sure which, though.
