Rocketdog
- Sep 28, 2023
- New Hampshire
- 1995 Mercury Cougar XR7 Restomod DOHC V8
We plan to run this car at Loring this year. We have a lot to do, but I am within sight of sending the car to the Mac to have him install the 10 point cage. That milestone has been hard coming to.
I am putting together a list of "must have" items for procurement. I need the help of brother members in selecting the proper final drive.
I was under the impression LSR was all flying start. Wrong again. This course is 2.7 miles of taxiway with timing at 1 and 1.5 miles. The start is "standing", and the "go" command comes from the marshal.
Here is the "street" setup right now:
Tires: 27.9"
Final drive: 3.73:1
Traction Lock
Cast housing
10" 3800-4400rpm stall torque converter with anti-balloon plate
Force lubed, J-modded 4R70W
4" one piece aluminum shaft
I have the open 3.07 in the aluminum housing from my Mark donor car to work with.
My instinct tells me this is almost right for an NA DOHC car for the mile.
It's a stock gen 2 engine with a 25% UD harmonic and the Cougar's Ignition (speed coils). I have the IMRCs wired wide open and by then I should have long tubes on it. Even well tuned it's probably only 300-305hp.
With a flying start I would go open and long, like 2.73 or longer even. I am not seeing the car topping out in third gear inside a mile. If it does hit the limiter, I guess we could back off and let it have 4th gear. Seems a scary prospect to shift at that speed.
