Jae 'Bird
5th Gear Poster
- Dec 11, 2023
- Age
- 20
- Edmonton, Canada
- 1990 Ford Thunderbird Base with PEP 151A, 3.8L NA V-6
So I am going to be pulling the car out of storage very soon and the first thing I want to do is change the tranny fluid. I want this to be a thread for others to reference in the future regarding the AOD fluid change and also a double check thread where I make sure I have everything in order to make this go smoothly (and a place to ask questions if something unexpected happens). I will list the tools and parts I have and then you can add things in that I either might want or absolutely need for this process. If I don't mention it, please ask if I have it (parts or tools) even if it seems obvious, I will not take it as an insult, I liked getting double checked. I will also have some questions farther down
So far I've got
- a safe way to lift and support the car
- wrenches and everything I think I'll need to remove the bolts and whatnot
- Breaker bar to turn the engine to get the torque converter bolt accessible
- 12 Qts of Mercon transmission fluid (Canadian Tire still has mercon and it was on sale)
- 1 Qt of Lucas transmission fix
- Wix transmission fluid filter and new pan gasket
- pan cleaning things (brake clean, rags, plastic razor for the sealing surfaces)
- drain pan and a way to measure how much fluid comes out
- Thread locker if I need it but I don't think its needed for any bolts
- torque wrench to properly torque the bolts
- Haynes manual to reference and for the torque specs
The reason for the lucas is I used it several years ago because shifting it was a little sharp and it helped quite a bit, I also like it for a preventative measure going back together to keep the clutches good. I assume this is original fluid coming out as my Dad (the previous and only other owner, doesn't recall the fluid every being changed). However, I have always kept a close eye on it and it is always at the right level and is still a decent pink color so I think I am safe to change it, the car has 181,000 km (112,468 miles)
Now for some quick questions,
I want to confirm that draining the torque converter is fairly easy, I think i just turn the engine until the plug shows and then undo it right? I don't need to remove extra parts to get to it right?
is there any checks or things I should look for while I'm looking at the bottom of the valve body with the pan off?
Are there any torque specs that aren't in the manual that I need to know?
I appreciate any and all input, this will be my first time doing this maintenance.
So far I've got
