Have you been able to tell if it's truly been better at any point during this journey?
I just ask that as I'm wondering if it's something altogether unrelated. Are you always on the brakes when it occurs? Any odd braking feel?
What are you running for wheels and tires. There's not a chance tires are contacting the upper control arm/spindle, is there?
Other random thought, but I know there have been folks with cracks in the fire wall. Flexing metal that's rubbing could cause a nose like this.
I am running 235 55r17s, but i see no way it would make contact.
Really aside from inlinks i still think it has something to do with strut rods, but its not the stripped threads, that would be passenger side and the noise is barely audible on that side, and mech cleaned them up and was able to get stuff tight
I have really been considering inlinks again, because with how this pop likes to play hide and seek. im not really sure if it went away or stayed removing them, but other things have been replaced since. they were one of the first things i replaced too and i had to fight to get the old ones off.
The noise only happens under load, when the weight shifts hitting a pot hole or entering my driveway. i cant replicate it winding around in a level lot. Whatever pivots gets stuck, and then sets itself free when im on level ground or the car is sailing straight.
Atleast the intermittent noise is like that. Which i wouldnt be suprised if it is something else. inlinks that i overlooked or maybe the uca
however, In the rain i have a persistent popping that feels just like when the last shop had to "shim" the strut rod bushings. just a clunk/ pop every time i hit the brakes and let off, and it also sounds louder on the drivers side. So i guess my brain keeps tying the noises together, but both of the exact same noises have happened to varying degrees ever since having the old shop redo the front.
When they shimmed the moog bushings that were replaced under warrenty the car got tigther, the persistent popping went away but i still had the same rain clunk, and intermittent popping. same with the lincoln continentals.
