I was mainly wondering if change in load on the suspension would cause a broken coil to shift and pop back into place. Like I said, it was a long shot, but I was reminded of it while doing some brake work on my car. I'd almost be tempted to remove the shock and articulate the suspension to see if you could reproduce the sound/motion. I'm surprised that you can't see anything with any of the videos. In the first video you posted you can see the camera shake when it pops. You can usually see when something moves like that.
If there is some rhyme to my own recent reasoning, which seems very doubtful based on the opinions ive recieved. The only visible movement would be captured at the front most bushing. if it was actually acting as a plane that can slip and make the sleeve ping the frame bracket or just the bushing itself teeter tottering and snapping when it finds a resting position
In my mind the flanged bushing should be at the front most of the rod. When the wheels go back that rod wants to suck backwards aswell and the bushing that would take the most brunt force load is the front most (ie braking at 60mph forward vs 10mph in reverse). So i just think the flat bushing belongs at the rear because well all it needs to do is sit against the washer/ jam nut and frame (which to my knowledge doesnt have a raised lip on the rear subframe side)
I just dont see how they could center properly without what is basically a flanged pilot bushing not being at the front most of that assembly. The rod would also be the strongest thing inbetween that and the frame bracket no? if something wants to move past and cause a slip. it should also happen at the end most of the rod where i would have very little centering.
Ive never had an issue like this on any of my cars, and 99% of the front end is brand spanking new. i would again point to the moogs and their orientation. that set did not explode, but still made the same pop on braking intermittently. That is the only tangible thing to support my theory.
I have also had 2 shop owners tell me im either losing my mind and the pop isnt there or that i should just toss the polyurethane bushings and find natural rubber. which i have, but i would dare them to install those in the same orientation they did the moogs/ polyurethane from bill
edit: another thing if my assumption about the frame bracket is correct. the flanged bushing, sitting inside the flanged raised lip on the frame bracket would basically be securing what in my mind is a pilot bushing for the end of the strut rod. Flange inside flange, but if there is also a lip on the inner frame side, im dead wrong
