Wipers. 1 out of 3 put themselves away.
3_97_Sports
BC Canada
I have 3 97 sports
On 2 of them, when you turn the wipers off, the wipers go to the off position and stay there, blocking the view above the hood.
On the other one, the wipers go to that same off position but then they go down and tuck themselves away closer to the cowl.
What is the difference in these 2 different setups in the same year/model cars?
It is not a wiper arm placement issue, the 2 motors just don't make that tuck away movement.
We talked about that here recently because I was considering a retrofit. Not sure if it was its own thread or in one of the daily threads; I'll check.
The tuck away movement was only on the Mark. If you have it on a Bird, it was either retrofit or a spec I haven't heard of. It requires a different motor/gear and control module.
Here's the thread:
I am pretty sure that car was unmolested when I got it, I don't drive that one anymore. I should pop the cowl off and swap the motors, and get a part number of what I have in there.
I moved it across town the other day, and when I turned the wiper off, I remembered that was a thing on that particular car.
The wiper linkage seems sloppy and has a lot of play on these cars. Adjusting the arm position helps a bit with getting them to park in the correct position. But depending on how much drag is on the wipers when they are being used, seems to account for them stopping about half an inch in either direction.
Not sure if that was how they were when new, or if it's just the bushings getting worn out from time. Either way the wiper setup on these cars is a 4/10 IMO
Got me curious to find out what's up.
The other 2 aren't broken or extremely sloppy or anything, they just don't even attempt to make a hide away motion.
