I'm about to order a rebuild kit and I'm wondering if it makes a difference if I put in 2-groove accumulators or 3-groove accumulators or is this something I have to disassemble to find out what I have to replace it with the same kind?
Thank you for your comment. I have no idea why you took the time to leave it. No useful information contained within.Yes they offer different grooves.
If you can weld, grind, and measure and follow rebuild instructions you can figure it out.
possibly slight length differences?
I did intend to use the OD pin with O-rings from Sonnax in my build, but I never mentioned this in my original post. Others did, possibly relating the grooves on the OD pin to O-ring grooves, I don't know. My research from several sources indicates that the O-rings on the OD pin assure a good seal IF the pin bore is less than perfect. I'm assuming mine is less than perfect!The only reason you would need the one with the orings is if the bore is damaged. The thing to check there, is the pin bore, and see of it's slopped out, It will leak, and will not hold. A slipping odband smokes the seals in the direct clutch. But there's no reason not to use the one with he o-rings. I'm using it in one of them. Dirtydog recommended those for certain applications.
