Wanted 94-97 steering shaft
Want to Buy
XR7-4.6
Administrator
Staff member
Roselle, IL
1994 Cougar XR7 DOHC TR3650
Title says it all, I’m going from Mustang manifolds/custom steering shaft to MN12 Kooks headers and now need the stock assembly. I only need the section from the column U joint to the rag joint, not the boot(I still have my original).
I was saving it in case I needed to do some double or triple joints to clear my headers. If yours is in a couple pieces, I'd swap you. I did mangle the top cutting it off the pieces I sent to White Lincoln. LMK
View attachment 10882View attachment 10883
The column portion isn’t the section I’m after, I need the portion that goes from the colum through the firewall to the rack
I didn't find it. Can't believe I threw it away. I'll keep looking.
There was a guy on FB that had a parts car yesterday. Engine and trans were pulled, so it should be an easy pick.
I'll check tonight, I might have one.
Thanks guys. Tbscshop has one as my backup plan but it looks way rustier than a part that’s half in the interior should be.
Took a look and can't find one. Might have out at my dads but not sure when I'm heading out there.
I was at my local yard last week and for the first time ever there was only a single MN12. If you don't find anything I'm sure I can grab you a nice rust free Vegas part.
