In February of this year (2024) when I bought my less-than 100K miles, non-running white 96 4.6 Bird with ONLY* a bad fuel pump, the outdoor temps were in the 25-50 degree range.  Well, now in June, the temps are in the 85-95 degree range, today being the hottest day yet this year at around 98, I really wanted to get my air conditioning running.
I knew it was a gamble, but I thought it might be a good one. I pulled a vacuum on it last week and it only dropped 2 inches of mercury over 2 days. I figured I'd charge it up and see what happened. I bought a full 36-oz charge of R-134a today at the auto-parts store for a grand total of $34 and some change. I promptly drive home and pull it up on the concrete and once again pull a vacuum on the system. I then proceeded to empty the 3 cans of freon into the low-pressure port. After the first can I hear the AC compressor clutch start to quick-cycle on and off. After the second can it stopped cycling. I emptied the last can and disconnected the gauges.
I moved around to the open window and expected to find ice-cold air coming out of the vents. I was quite disappointed to feel that I had the heat on instead of the air conditioning! I'm pretty bummed that I just wasted $35 but I knew it was a gamble. I lost.
So I have another 4.6 parts bird that I pulled a vacuum on last week as well. Over three days it lost 10" of mercury. I was thinking of swapping this compressor in to the white 96 and see if it works. It would be nice to be able to test it out before I install it but I do not know if it is possible. Is it? Also, I have a V6 parts car, I was wondering if the AC compressors are the same between the V6 cars and the V8 cars since the V6 compressor is much easier to get to. Any helpful ideas would be welcomed. I'm just wondering if I should just buy another compressor, condenser and drier and just redo the entire system, but I'm not going to pull the dash to replace the evaporator coil so I'm wondering if I should really even consider installing new stuff...
* Not only did I replace the fuel pump but the intake was leaking, the power steering rack and pump were shot, also the upper and lower ball joint and outer tie-rod ends. So much for a good deal...
 I'd want to touch the evaporator itself but that's not possible.   It's the one that goes to the accumulator.
		 Again, PV=NRT.
 Again, PV=NRT.
