Seems like a 96/97 headlight conversion would be much simpler than trying to fit something from a completely different car.
Now that’s funnyCougar guys have it easy
How much better do you think those expensive bulbs are over the cheaper ones?
200 is what I remember seeingI got a wild hair last night,and am looking to see if I can pull enough vacuum to redo the reflector inside the headlight. I I have spares. I'm going to bake them apart and take a look at what's up with them. So, 100degrees for an hour, or 200?
For just a few minutes though, not an hour. The goal is to soften up the adhesive so it's pliable, not create a mess in the oven.200 is what I remember seeing
Interesting. Did you need any of the options listed or just the bulbs themselves? What makes these so much better than the cheap LED bulbs? How do you like the color? I recall reading elsewhere that somebody recommended a max of 4300k, but I forget where that was.
4300K is the OG HID color temperature. You're generally not going to find an LED headlight bulb in that color temperature because they're pretty much all 5000K and above. The GTR Ultra 3 is rated at 5750K which is pretty good.3000k is a yellow fog light. 4300k is your standard halogen headlight. 5000k is about what a factory OE LED headlamp is. 6000k is that annoying ricer blue/white.
4300k is what you want.
Just the GTR bulbs (LEDs) themselves, nothing else.
These are significantly brighter than the cheap Amazon bulbs, not sure because they're brighter or if the LED element is better positioned than the cheap Amazon LEDs.
The color isn't my favorite, but it's alright. It's a little bit more blue than I'd like for myself. IMO, if they were 5500k, I think I'd like the color better.
I’d assume it’s the filament placement. I had a pair of aliexpress ones in my old headlights and had to modify them to get into the correct orientation.
