CDsDontBurn
My T-Bird has been sitting for like 6yrs and it's been about 4yrs since I last cranked the engine over and let it run to normal operating temperature. In the coming months or so, I will be (finally) moving it into the garage so I can get working on it. The questions I have are:
- Do I need to worry a about any sort of internal engine rust?
- Can I run it for a short period of time with the existing fluids (oil, coolant, ATF)
- What are things I should watch out for not fluid related?
- What are some checklist type items I should do before even thinking of turning the engine on?
- What do I need to concern myself in regards to any remaining fuel in the tank (appx 1/4 tank at last startup)?
- Should I push it into the garage or drive (limp) it into the garage considering the above questions?
- ATF is currently low, likely dangerously low, should I get some ATF in there before even attempting this as I will be pulling out the AT for rebuild anyway?
