- Oct 2, 2023
- New Mexico
Any one have a good idea how to keep car ramps still on a smooth garage floor when you drive the car up on the ramp?
This is similar to what I have. 1/2" plywood about 15" longer than the ramps, with a 2x4 screwed on the end to keep the ramp from sliding.Mine are plastic, but they still slip, I cut 2 pieces of plywood a few inches wider than the ramps, and about a foot longer.
I screwed a 2x2 across the end of each one, and place the ramps up against the 2x2.
This leaves 10 inches or so that sticks out underneath the ramps sloped end, so when you approach the ramps, the weight of the car is holding the plywood down, and the ramps are pressed against the 2x2, they cannot slide out on you.
I usually drive up onto the wood, then check to make sure they are still pointed straight before driving up the slope.
