Common Acronyms
theterminator93
Administrator
Staff member
North Ridgeville, OH
    1997 Thunderbird 4.6, 1998 Mark VIII LSC
    I've compiled a list of some of the more commonly used acronyms you might find on the site, in the context of how they're likely being used on the site. I've tried to omit the silly/less useful ones, but if there are some you can think of that I've missed, let me know and I'll add to the list.
    Technical/Car Related Acronyms/Abbreviations
    2V = 2-Valve (SOHC)
    3V = 3-Valve (SOHC)
    4V = 4-Valve (DOHC)
    AC = Alternating Current
    A/F = Air to Fuel
    A/T = Automatic Transmission
    ABS = Anti-lock Braking System
    ACT = Air Charge Temperature
    ATDC = After Top Dead Center
    BHP = Brake Horsepower
    BOO = Brake On/Off
    BSFC = Brake Specific Fuel Consumption
    BTDC = Before Top Dead Center
    CAI = Cold Air Intake
    CCRM = Computer/Constant Control Relay Module
    CEL = Check Engine Light
    C[K]PS = Crankshaft/Camshaft Position Sensor
    COP = Coil On Plug
    CTS = Coolant Temperature Sensor/Sender
    CV = Crown Victoria/Constant Velocity
    DC = Direct Current
    DIN refers to size 2″ x 8″ opening that a radio fits into. DIN stands for Duetch Industri Normen (German Industry Standards) which the Germans starting using to standardize the radios in Audis, BMWs, Mercedes and VWs way back in the mid 80’s. It has since become the industry standard.
    DOUBLE DIN is the same width of 8″ but is 4″ instead of 2″.
    DIS = Distributorless Ignition System
    DMM = Digital Multimeter
    DOHC = Double Overhead Camshaft
    DPFE = Differential Pressure Feedback EGR
    DS = Drive Shaft
    DTC = Diagnostic Trouble Code
    EATC = Electronic Automatic Temeprature Control
    ECT = Engine Coolant Temperature
    ECM = Engine Control Module*
    ECU = Electronic Control Unit
    EDIS = Electronic Distributorless Ignition System
    EEC = Electronic Engine Control*
    EFI = Electronic Fuel Injection
    EGR = Exhaust Gas Recirculation
    EGT = Exhaust Gas Temperature
    ET = Elapsed Time
    EVAP = Evaporative Emissions
    EVO = Electronic Variable Orifice
    EVTM = Electrical and Vacuum Troubleshooting Manual
    EVR = EGR Vacuum Regulator
    FFS = Feedback Fuel System
    F/I = Forced Induction [engine]
    FN10 = Full-size North American Project #10 (93-98 Mark VIII)
    FP = Fuel Pump
    FPDM = Fuel Pump Driver Module
    FPR = Fuel Pressure Regulator
    FSM = Factory Service Manual
    FSSB = Front Suspension Support Brace
    HCI = Heads/Cam/Intake
    HEGO = Heated Exhaust Gas Oxygen Sensor
    HO = High Output
    [H]O₂S = [Heated] Oxygen Sensor
    IAC = Idle Air Control
    IAT = Intake Air Temperature
    IRCM = Integrated Relay Control Module
    IRS = Independent Rear Suspension
    IMRC = Intake Manifold Runner Control
    J-mod = Jerry's transmission modification
    KOEO = Key On Engine Off
    KOER = Key On Engine Running
    LCA = Lower Control Arm
    LECB = Lower Engine Cradle Brace
    LTFT = Long Term Fuel Trim
    MAF = Mass Airflow [sensor]
    MFS = Multi Function Switch "Blinker Switch"
    MIL = Malfunction Indicator Lamp
    M/T = Manual Transmission
    MLPS = Manual Lever Position Sensor
    MN12 = Mid-size North American Project #12 (89-97 T-bird/Cougar)
    N/A = Naturally Aspirated [engine]
    NPI = Non-Performance Improved
    NOS = Nitrous Oxide System/New Old Stock
    NSS = Neutral Safety Switch
    NVH = Noise/Vibration/Harshness
    OBD-I = On-Board Diagnostic system Rev. 1
    OBD-II = On-Board Diagnostic system Rev. 2
    OD = Overdrive
    ODA = On Device Adjust
    OE[M] = Original Equipment [Manufacturer]
    P/A = Power Adder [engine]
    PC/ED = Powertrain Control/Emission Diagnostics
    PCM = Powertrain Control Module*
    PCV = Positive Crankcase Ventilation
    PFE = Pressure Feedback EGR
    PI = Performance Improved
    PID = Parameter ID
    PnP = Ported and Polished
    PTV = Piston to Valve
    RKEM = Remote/Keyless Entry Module
    RPM = Revolutions Per Minute
    RTLB = Rear Torsional Load Bracing
    RWHP = Rear Wheel Horsepower
    RWTQ = Rear Wheel Torque
    SATC = Semi-Automatic Temperature Control
    SC = Super Coupe/Supercharger
    SFC = Subframe Connector
    SOHC = Single Overhead Camshaft
    STB = Shock Tower Brace
    STFT = Short Term Fuel Trims
    TB = Throttle Body
    TC[C] = Torque Converter [Clutch]
    TDC = Top Dead Center
    TOT = Transmission Oil Temperature
    TTY = Torque To Yield
    TPS = Throttle Position Sensor
    TSU = Temperature Sending Unit
    TV = Throttle Valve
    UCA = Upper Control Arm
    VAPS = Variable Assist Power Steering
    VMM = Vehicle Maintenance Monitor
    VSS = Vehicle Speed Sensor
    WOT = Wide Open Throttle
    Misc. Acronyms/Abbreviations
    AED = Allen Engine Development
    AFAIK = As Far As I Know
    BTW = By The Way
    SCCoA = Super Coupe Club of America
    FRPP = Ford Racing Performance Parts
    FWIW = For Whatever It's Worth
    IIRC = If I Recall/Remember Correctly
    IME = In My Experience(s)
    IM[H]O = In My [Humble/Honest] Opinion
    N/m = No Message/Nevermind
    NIB = New In Box
    OP = Original Poster
    PBR = Paton's Brake Replacements
    QFT = Quoted For [the] Truth
    QH = [Moates] Quarterhorse
    SCT = Superchips Custom Tuning
    TSB = Technical Service Bulletin
    TSTSNBN = The Site That Shall Not Be Named
    TY = Thank You
    TTT = To The Top
    X2/X3/+1 = Showing agreement with a previous statement
    YMMV = Your Mileage May Vary
    * = A reference to a computer. For MN12s and FN10s, many of the different functionalities of specific types of computers in other cars was combined into the single unit PCM.
    2V = 2-Valve (SOHC)
    3V = 3-Valve (SOHC)
    4V = 4-Valve (DOHC)
    A/F = Air to Fuel
    BOO = Brake On/Off
    COP = Coil On Plug
    DC = Direct Current
    DS = Drive Shaft
    ET = Elapsed Time
    FP = Fuel Pump
    HO = High Output
    OD = Overdrive
    PID = Parameter ID
    TB = Throttle Body
    TV = Throttle Valve
    BTW = By The Way
    NIB = New In Box
    TY = Thank You
    TTT = To The Top
    RTFM = Read the Frickin' Manual
    Maybe sn95, s197, s550, s650, also scp for super coupe performance
    Back when I first started reading forums I thought QFT was Quit Fucking Talking. I thought so many people were rude trolls 😆
    I don’t know for sure but I think SN95 is Specialty-North American-project 95(ala MN12), and following that logic with later model Mustangs being global cars they were simply Specialty-197, Specialty-550, Specialty-650. That’s just an educated guess.
    TL,DR. PIIHB. Run like Hell.
