Airwolf-90
Newbie
- Oct 2, 2023
- Kingsville, Ontario
- 1990 T-Bird LX 232-TT "Airwolf"
Can you post some more pics? Am I wrong or is the block freshly prepped?Going to pull that cam bearing and look for a crack in the journal. Similar "groove" on the other side of the main, and on the other center main as well. Both sides of the mains.. doesn't look sharp enough to be a crack, but I don't know.
Just looking for more eyes on, and some opinions.
nothing JB weld can't fix![]()
Does spook me a bit.. think I'm going to push forward though. This is a learning project, I've never "blueprinted" an engine so this 3.8 is my first. Not looking to make huge power, mainly just go through the process of block prep, getting all my tolerances measured and bang on (prove oil clearances, not guess or assume). I want to make any mistakes on this E9SE block before I get into the 351w that's sitting in the corner waiting for it's chance to push the tbird around. Originally I WAS going to turbo this 3.8 but I don't know if that's a good thing now.That would definitely spook me from using that block. I'd go shopping for a SC block or a 96+ block, both are strengthened from the early NA blocks
I did actually.. smacked it around a bit with no issues.Hit it with a hammer. If it breaks, it was a crack. If not, you'll probably still need a new block anyways.
Trying to grind them out today.. we'll see how that goes.I'd call those stress risers, and grind them smooth.
Anyway, crack is bad, mmmk.
Yeah, I've got some additional pics.. in the process of prepping the block. I saw those lines but didn't really think much of them until I got down into it and realized they were more than just shadows once I cleaned up the block.Can you post some more pics? Am I wrong or is the block freshly prepped?
Thanks for the assessment! Haven't pulled that cam bearing yet but I will update once I've done that. This "artifact" in the casting is present on both sides. Got info from a few Ford foundry worker types (I live right near Windsor, ON where the casting plant is/was) and they're thinking "cold pour". Block may still be okay for stock power levels (it already has 170k km on it - pulled it from my tbird that ran fine.. no clangs, bangs, knocks or pops).That's a crack emanating from a stress riser in the casting extending up to the horizonal joint. I'd find another block. Put an inspection mirror in that lower hole and see how deep the crack is in that location. I'm certain that it will turn the corner and be visible into that penetration. What does the other side look like?
Trunk Monkey
American Society of Nondestructive Testing Level II inspector (ASNT II) AND American Welding Society Certified Weld Inspector (AWS CWI).
No charge for the professional assessment.Tips appreciated! LOL
Donations can be made to the club by clicking on your username in the upper right hand corner and selecting account upgrades.
Grinding today.I'd call those stress risers, and grind them smooth.
That chip is probably some in-progress radius work I'm doing on the block, if we're looking at the same thing.I'd say it's a crack you can follow it all the way to where there is a chip missing in upper left of picture
Grinding today.
I may just turbo anyway.. we're not talking 20psi, more like 7psi. I can probably keep it out of detonation.. if she pops, she pops.Yeah with a twin turbo I'd not use that block even if that is a casting artifact, the older 3.8 blocks just aren't built for boost like the SC blocks are(and 96+ blocks are friendly to). As a learning project though that'll be adequate I imagine. I don't necessarily think that's a crack, but if you were to test the limits of the block, I do bet that main would turn that into an actual crack!
351W sounds fun, that foundation would be my pick if I had to start all over again.
Well I can't find my cam bearing tool, so they're still in there. Carbide burr took care of that casting artifact.. I think?
They used to sell purple uv reactive dye at all the parts stores for just this use. I would clean a part with brake parts cleaner, spray it with the dye, clean off the excess with a towel and isopropinol. baby powder, powdered sugar, flour, pretty much any fine powder wiill work. Your cocaine stash is probably not the best thing, lol.
Was he ever busted for that? I know he did time as a kid for gun charges.
Either way it's not hard to sniff out a crackhead from the litigants on his show.
What a difference a day makes!Well I can't find my cam bearing tool, so they're still in there. Carbide burr took care of that casting artifact.. I think?
That's great info.. love these little tricks of the trade.You can do a poor man's penetrant test (PT) test on the area (like they did in the old days on the railroad). Clean the area with isopropyl alcohol, apply a light oil - cooking oil or other light weight oil to the area (not WD-40 light but something light), let soak for about 5 minutes. Clean the area again with alcohol and let dry. Then lightly sprinkle the area with baby powder and look for it to draw the oil out of any cracks or porosity in the casting in that area.
Be sure to apply the oil up to and over the horizontal joint on both sides of that area.
If it's cracked you'll see it.
lol none of that around here for at least a decade.They used to sell purple uv reactive dye at all the parts stores for just this use. I would clean a part with brake parts cleaner, spray it with the dye, clean off the excess with a towel and isopropinol. baby powder, powdered sugar, flour, pretty much any fine powder wiill work. Your cocaine stash is probably not the best thing, lol.
