girdnerg
- Sep 24, 2023
- Eastern Oklahoma
- 1994 Ford Thunderbird LX 4.6L V8
Car overheated today. Tracked down a burnt/melted fan fuse under the hood. That fuse spot is also melted. This must be a common problem. I have a spare fuse block from a donor car and when I removed its cooling fan fuse, it was starting to get brown where the old one melted.
I have the fuse panel open and have figured out how to move the wire and fuse over to an unused spot. I was able to get the wire out of the melted socket. The wire insulation is melted off the last 3 inches or so. I ran a jumper with fuse to the damaged wire and the fan spun up.
I could use some help with this
1. Do I need to replace the section of wire the insulation melted off of or can I just wrap it? The wire is there but discolored from the heat.
2. If I do need to replace it, what is the best method? Butt connector, twist and solder, or ??
3. Most likely culprit seems to be the cooling fan going out. Tips on how to test the fan? If I spin it by hand, what am I looking for? Any way to use a ohm meter to test it?
Thanks guys
Thanks guys
