Engine specs, 4.6 2V, 4.6 4V, and 5.0
Status
Not open for further replies.
MadMikeyL
Tinton Falls, NJ
4.6L DOHC (96-98 Cobra)4.6L DOHC (Mark VIII)4.6L SOHC NPI5.0L OHV
Engine90 degree DOHC V-890 degree DOHC V-890 degree SOHC V-890 degree OHV V-8
Displacement281 cubic inches281 cubic inches281 cubic inches302 cubic inches or 4,942 cc
Valve train4 Overhead camshafts driven by chains4 Overhead camshafts driven by chains2 Overhead camshafts driven via chainsOne in-block camshaft driven via chain
Valves32; 4 per cylinder32; 4 per cylinder16; 2 per cylinder16; 2 per cylinder
Cylinder headsCast aluminumCast aluminumCast aluminiumCast iron
Cylinder blockCast aluminum with a 6-bolt mainCast aluminum with a 6-bolt mainCast iron with a 4-bolt mainCast iron with 2-bolt main
Bore X Stroke3.552 x 3.543 inches3.552 x 3.543 inches3.552 x 3.543 inches4.00 x 3.00 inches
Compression ratio9.85:19.8:19.0:19.0:1
TransmissionT-454R70W4R70WAOD
ExtraCamshafts are more aggressive
Forged crankshaft
COP ignition for 97-98
'91-'93 HP & TQ SAE-net200 hp @ 4,000 rpm
275 lbs.-ft. of torque @ 3,000 rpm
'94-'95 HP & TQ SAE-net205 hp @ 4,500 rpm
265 lbs.-ft. of torque @ 3,200 rpm
'96-'97 HP & TQ SAE-net205 hp @ 4,250 rpm
280 lbs.-ft. of torque @ 3,000 rpm
'93-'96 HP & TQ SAE-net
(base models)
280 hp @ 5,500 rpm
285 lbs.-ft of torque @ 4,500 rpm
'95-'96 HP & TQ SAE-net
(LSC models)
290 hp @ 5,500 rpm
290 lbs.-ft of torque @ 4,500 rpm
'97-'98 HP & TQ SAE-net
(base models)
285 hp @ 5,750 rpm
280 lbs.-ft of torque @ 4,500 rpm
(LSC models)
290 hp @ 5,750 rpm
'96-98 HP & TQ SAE-net305 hp @ 5,800 rpm
300 lbs.-ft of torque @ 4,800 rpm
'99 Mustang (PI) HP & TQ SAE-net260 hp @ 5,250 rpm
302 lbs.-ft. of torque @ 4,000 rpm
Status
