FYI: Driveshaft Lengths
Rodeo Joe
Staff member
Lifetime Supporter
Franklin, MA
    1997 Thunderbird LX 3.8L/4.2 Wannabe
    In the past I've noticed 1994-97 3.8L owners inquiring about or actually buying a 1993 Mark VIII one piece driveshaft as an upgrade. Little do they know that it won't fit! :zrant:
    So I thought it would be a good idea to pass some information along. The complaint from people is they didn't know that the 3.8L 4R70W car has a driveshaft that's 1.20" shorter than the 4.6L car.
    MODEL YEARSENGINETRANSMISSIONDRIVESHAFT LENGTH
    94-973.8L V64R70W57" driveshaft
    94-974.6L V84R70W58.20" driveshaft
    93-98 MARK VIII4.6L V8M5R258.20" driveshaft
    89-953.8L V6AOD53.80" driveshaft
    89-933.8L V6AOD57.80" driveshaft
    89-935.0 V8AOD57.80" driveshaft
    94-97 3.8L 4R70W 57" driveshaft
    94-97 4.6L 4R70W 58.20" driveshaft
    93-98 Mark VIII 4R70W 58.20" driveshaft
    89-95 3.8L M5R2 53.80" driveshaft
    89-93 3.8L AOD 57.80" driveshaft
    89-93 5.0 AOD 57.80" driveshaft
    These specs are from a previous group purchase.
    Is the driveshaft on the 5.0L stronger than the one on the 3.8L? Maybe cause of more torque? I would maybe upgrade if it was better not that I would really the upgrade
    I wouldn't think so. Anything stronger is to get away from the stock 2 piece and go aftermarket.
    Driveshaft attributes are more determined by rpm(critical speed) than strength. The diff and halfshafts are beefier on SCs and V8s(apart from some ABS V6 NAs that got 8.8s when 7.5 ABS cases weren’t available).
    Anyone happen to know the bolt pattern on the pinion flange? Sounds like it's either 3.5 or 4.25 according to PST. I was trying to order as I got measurements for everything but that. Didn't know there were different flanges.
    Just for future references of anyone looking to order, PST is running $704 with the 3.5" rear flange, 1330 u joints and in aluminum. Mine measured 61.75 inches from output seal to pinion flange with the AJE cross-member on the lowered red series motor mounts. The 1330 joints are the limiting factor, so this should be good to 750hp.
    Edit: received yesterday and it fits perfect!
