How-To: Door Panel Ambient Lighting
Let's start with the end product. Sorry, this is the best my phone camera can do:
20230130_181809-jpg.52302
20230130_181437-jpg.52303
20230130_181541-jpg.52301
Step 1
Obtain LED elements. I went for 2011 Mini Cooper coupe/hardtop RGB elements ($1.99 a piece from my local junkyard); however, I am only using the green feed. If you feel creative, you could wire up the red and blue feeds for more color options.
Step 2
Remove the door switch panels. They pop out towards the front, then unhook aft of the door release. Disconnect from wiring harnesses (remove screws).
Step 3
Make hole for LED element (I used a Dremel to make a rectangular hole) at aft bottom of the door release cavity. Install LED element. Apply reflective tape along the top of the cavity (I used a combination of aluminum foil and double-sided carpet tape).
20230129_103415-jpg.52304
20230130_084028-jpg.52305
Just for perspective, here is the clearance between the LED element and the door panel as seen from behind. It is snug:
20230129_103507-jpg.52306
Step 4
Connect the wiring. Ground to the door. Connect the power feed to the door switch illumination (white/purple):
screenshot_20230130_182905-jpg.52307
20230128_124520-jpg.52308
Attention: This feed is not part of the dimmed circuit; it stays at full bright regardless of dimmer position. If you want a dimmed light, you will have to feed wires from the dash (which is a PITA, see my door courtesy light retrofit write-up).
Step 5
Reconnect all connectors and reinstall door switch panels. Here is the LED element as seen from the front; however, from any "normal" perspective, it is completely hidden:
20230129_170639-jpg.52309
Have fun!
