Intermittent tach issue in my 92 SC
Kurt K
Missouri
1992 Thunderbird SC 3.8L SC
I've had an issue for several years that the tach will drop to zero and a check engine light will appear when I'm driving. It never happens when the outside temperature is below 45-50 degrees....even in the summer, everything will be fine until I get to the 1st extended stop light. So I know the issue is heat related. When the tach drops to zero, the car still runs fine. I've changes the cam and crank sensors and I still get the intermittent issue.
I assume it is something to do with old wiring under the hood, but I'm not sure where to start. Or is it possible that the tach itself is the problem?
I would suspect the DIS module. If you have a spare OEM one, I would swap that out and see if the problem goes away.
Actually, I replaced that too, but forgot to mention it.
