Should 8oz of PAG 46 be enough oil?
Thanks, not replacing it the compressor is still goodAre you replacing the compressor ? If not, you dont need to add oil.
It might, but I'm always suspicious of products when they don't actually say what the product is on the label. There are different viscosity PAG oils. Plus, I usually manually add the oil to the parts before I install them. I normally buy the stuff in the bottle like terminator posted.Would a 3oz can of this be a good idea then?
I've got a kit of the purple EPDM o-rings, planning to replace the ones I can easily get to
I've got to figure mine out as my system shows ZERO psi on low side and compressor won't kick on. I should vacuum and see if it will hold. Damn hot these days to boot.
