- Oct 2, 2023
- New Mexico
Good day,
I replaced the pinion seal on my Town Car recently, but when I took the car off the jacks and for a test drive, I get this clicking or clunking noise when in reverse. And the drive shaft sounds like it is out of balance, but this is at 5-6 mph. Driving forward does not have the same results. I put the car back up on jacks and checked the parking brake and it was not that. I ran the car in 1st gear on jacks to keep the speed down to 5mph and drive shaft is not turning that much. The clunking is coming from the u-joint / pinion gear area. I also pulled the U-Joints and inspected them and they were in good condition still. I thought I tightened the pinion nut correctly per the notch I made with the pinion gear shaft and the nut, but the more I read, it would seem I have it too tight, as the symptoms are similar to the nut being too tight. I even wondered if I got the diff pinion gears (spider gears) were off a gear, but that would be impossible because you can't put the cross pin in if they were off.
I am going to take the car into Ford cause my back can't take another round of jacking and crawling, but wanted to know more or less what to tell them I think the issue is.
If I did not tighten the pinion nut enough, would it cause the same issues? I didn't see anything about not tightening enough issues.
