I thought our cars used the post-cat O2 sensors to adjust fuel trim. Did I imagine reading that somewhere?
The exhaust system on this car has been mangled. For some reason somebody cut each pipe after the cats an then re-welded them back together (pretty horrible job). It fits the manifolds without hitting anything else but its pretty bent out of shape. As far as i can tell visually looking in to the cats, they are not clogged.
I'm running some Berrymans injector cleaner in the fuel but the injectors were clean of carbon when I put them in. I HAVE new O2 sensors but I really hate to throw the parts cannon at it until I can check the simple things. The short-term fuel trims are fine at less than 5%. I'm assuming that means the pre-cat O2s are working correctly?
I also have a new MAF sensor as I'm sure the one in it is original, again, parts cannon and all. I bought all these parts years ago when they were way cheaper and I hate to use them if I don't know the existing ones are bad.
Clean air filter, new fuel filter. The tank on this car was the worst I have ever seen. I'm not using the same injectors that came out of the car. Pretty sure I have taken care of all the vacuum leaks.
I suppose I'll clean the MAF first but I'm not hopeful. Any other suggestions before I change the O2s?
