I rebuilt the front end last year and need to order parts to hopefully get the rear done soon. I'm a little confused from looking at the factory manual (CD) and parts house descriptions.
The manual says "upper rear suspension arm and bushing (2 req'd each side)", but the diagram shows one place for the bushing. I see rear-to-frame bushing kits with 2 bushings, so are there inner and outer bushings at that one location on the upper arm, so I need one kit per side?
The manual shows a bushing at the knuckle top and the part for sale is "rear at knuckle". Is that the part for this location?
The manual points at a lower knuckle bushing location and calls it "lower rear suspension arm and bushing". That's #8 on the diagram and there are 3 locations pointed to (the 4th one is to be inferred I presume). Is this one bushing part meant for all 4 locations (2 lower knuckle and 2 lower arm (front & rearmost)?
I've had the toe compensators in storage for years, just haven't gotten around to the rebuild. I may have sway bar links around here, too, but if not, I'll order them. What I need is clarification on exactly what bushings I need to purchase and how many. I have a Schley bushing press kit, so I hope to do this on vehicle.
Unless I'm mistaken, there is a total of 6 replaceable bushings per side, is that right?
There are only 4 bushings if I order 3 part numbers in various brands, yet in none of the RA descriptions for any brand does it say more than 1 required per side, but clearly there would be 2 missing. These are the only bushing types that seem available, so do I need to double up some of these?
rear to frame
rear upper to frame
rear at knuckle (upper)
rear to frame
rear upper to frame
