- Oct 2, 2023
- New Mexico
So, the 95 Town Car drinker side window motor started acting up then began stuttering and I knew what that meant. The plugs in the motor gear are in pieces. I take the door off and instead of drilling holes that I may or may not come close to the motor screws, I decided to replace the windows regulator as well. I bought one that was a close out back in 2021 that was for the front right window from RockAuto. I replaced the gear and plugs I recently bought for the motor and put every thing back together on the NEW regulator. It would not fit. I tried drilling a bigger hole on the bottom of the rail to allow some adjusting, but no dice. The windows would not go up all the way. I am thinking to myself, "check the part number on that regulator" knowing the history with RockAuto. Sure enough, the regulator is for a 95 Town Car BUT THE BACK right REAR window. For schitz sake. I also checked my order from back in 2021 and sure enough, it was listed as front right. I cleaned up the old regulator, re-lubed it and put it all back together.
I wrote RockAuto a nasty graham about how this happens more than it should and my first words in the letter were "I know you don't care, but...."
Thanks for letting me vent.
