SOLD: 1994-1996 Cluster Surround Panel
This is among the best I have seen! Taken from a 1994 with 140,000 miles which was last registered in 2014 (per inspection sticker). Column was lowered before removal.
  • Color: black
  • $250 plus packing/shipping
  • Used condition; all tabs, clips, screw holes intact (rare!)
  • Air vent included
The car was a bit of a mystery to me. Even though it hadn't been driven for 10 years, there were zero rodent droppings. On the other hand, the top of the dash had multiple cracks. Seats looked very clean. The outside looked very worn. Overall quite inconsistent.
I need one, but could never afford one at that price.
I know...but I can't let a beauty like this go for cheap. These sales pay for all my car's needs and wants.
If you put some work into it, you can get a "worn" unit and fix all the tabs, etc. yourself. Problem is many of them are literally cracked all the way through. Out of ten MN12s I see in junkyards, I find maximum one good-ish cluster surround.
The one I have in my daily driver has been repaired. Quite a few cracks repaired with epoxy embedded with cotton fabric strips. This one was broken on both sides right at the hump for the steering column. I was quite proud of my repair, until I noticed it had broken through again on one side. I'm not pulling it out again until I can find a good one to replace it. I'm sure all the repaired posts with metal clips will break off again...
You can buy abs plastic, that paints on. that on the back, and it;s good as new. use abs. It's like the stuff you use for pvc pipe.
