Stumbling At Startup
Hello All,
This isn't a new problem, but one that occurred today for the first time in a while, potentially because it was the first warmer day in a while.
After much reading, I have an idea what might be going on, but I wanted to pass it by you all.
Situation:
  • I'm running several shorter errands around town; engine is warm; time between drives is anywhere between 10 to 20 minutes.
  • Tank is almost full; 30 miles since last fill-up.
  • At startup of the warm engine, I get significant stumbling/sputtering accompanied by a slight whooshing sound for about 15 seconds (best guess), which can be shortened by revving the engine a bit; then the idle gradually normalizes.
  • Today I actually turned the engine back off, and then I cycled the ignition a few times; each time the fuel pump primed, I could hear the same whooshing sound.
  • When driving off, everything turns back to normal, except during the first few seconds of initial acceleration, when I'm hearing a sound akin to tiny rocks traveling through a pipe; that sounds comes from the right side and seems to travel backwards (as if through the fuel return line?).
All this leads me to the conclusion that there's some sort of fuel vapor condition. There are no visible leaks anywhere in the engine compartment nor under the car, nor any fuel smells that I can tell.
Any thoughts or advice what I can do to alleviate this?
My 96 would stumble at startup for a few seconds randomly. Came and went over the course of a few months. Seemed to get better after a snap of the throttle, though not every time.
After a while the OG fuel pump died. Might not be a bad idea to check your fuel pressure just to give some peace of mind - bonus points if you can verify fuel pressure while it's doing its "dance".
Normal fuel pressure is 39 PSI less manifold vacuum pressure; at idle that would be in the neighborhood of 29-31 PSI.
O'Reilly's has them as a loan a tool. I've had mixed results from them though, many times they don't fit on the schrader valve well and either leak or won't read pressure.
Fuel pressure gauge, is that something you can get as a loaner from the parts store?
If you do get a loaner, be sure it has the schrader valve fitting. I bought this on Amazon ($25) and it comes with the Ford schrader valve fitting.
Actron CP7818 Fuel Pressure Tester Kit (currenlty out of stock)​
I bought another brand on Amazon and it did not have the fitting, had to return it. It was crap anyway. So be sure that if you rent or buy, it has the Ford fitting or you will need to go find one.
Is this a misfire sound?
Old thread reawakening. With ambient temperatures rising, this symptom is resurfacing.
I just got a loaner fuel pressure tester from Autozone. So correct me if I'm wrong, but I check for:
  • Pressure at idle around 30 psi?
  • Pressure at X rpm around Y psi? Please specify.
  • Pressure maintained after engine shutoff for Z minutes/hours?
Alright...wtf.
The Schrader adapter from the test kit fits over the valve, but for some reason it doesn't catch the little pin. Unable to use this kit.
Alright...wtf.
Same issue I’ve had with those rentals. You can try another kit. I’ve had at least one work for me, but others not.
With our model of Ford, you will need the Ford fitting for the fuel pressure valve.
If I recall, the auto store loaners may not have that fitting and may not work on our model of Ford.
The kit  did have that fitting, specifically designated for Ford. Still didn't work.
:2eek:
Whaaaattt???? Get the f out of dodge....You do need to screw on pretty far to get a reading. And if my memory servers me, 9-10 people complained that the fitting broke either the first time or a few times after using it. So, it could have been a bad fitting. May want to give it another try from another store (if available) or just buy the tool. You can always use a fuel pressure regulator... :P
I know it pisses me off when I rent a tool and some SOB before me either broke the dang thing or left if filthy and it sucks to work with dirty tools.
I rented one from another Autozone today, and same thing. No reading. The kit looked new.
I was starting to wonder if the Schrader valve was stuck. So I attached the tester to my bicycle tire, and again no reading.
I'm just puzzled. I screwed it on as far as possible by hand. I don't want to use a tool; don't want to break anything.
Bottom line, I believe that there's something not entirely right. I'm not sure if it's the pressure regulator because there are no drivability issues at all. I'm more inclined to question whatever check valve exists in the pump.
When I turn off the car, I can hear noises from the fuel lines as if something trickles through for maybe 10 seconds.
You can try priming the pump a few times before startup and see if the symptoms still exhibit themselves.
My check valve has gotten so bad I need to prime 3-4 times.
At their age, I've had to replace several of the schrader valves on the fuel rails for Fords in the last couple years. Ford still sells the part. They are under $20. I've had the small valve part get damaged over the years. And some just leak eventually.
Maybe you have an issue with that piece.
Yeah, but aren't Schrader valves standardized?
This pressure tester also didn't read any pressure on my bicycle tire, which is at 50 psi.
The valve Ford uses on the fuel rail is their design. It is not the same schrader valve like in a tire valve stem. You unscrew the whole small thing from the rail and install a new one.
This is not a normal Schrader valve. I posted this listing because it was the quickest thing I could look up. PLease allow me to note that I have received counterfeit Ford products from sellers on Amazon. So if you want one of these. My recommendation is go to a Ford dealer. They are under $20 there. And you get the real Motorcraft stuff.
(y) I don't buy any car parts from Amazon unless it is something I just do not care about at all and/or can be easily replaced.
Glad I'm not the only one that has trouble with the Schrader valves on Ford fuel rails.
I had to swap schrader valves from one of my old 2V rails into the 4V one because fuel was leaking past the seals
I avoid pretty much anything car related from Amazon and EBay unless it’s used. Counterfeit items are out of control. I bought a NOS GT500 oil pump from a Ford distributor only because I couldn’t trust the equivalent Mallory oil pumps I’d been seeing elsewhere even for non-too good to be true prices on those sites.
I used to have a fuel pressure gauge but now I can't find it - haven't used it in at least 10 years .. yeah the tool does not have a pin to depress the "Schrader" valve pin; it requires an adapter. My GM has a ball style valve on the AC .. we call them Access valves; ford valves are not specific to ford .. they are made for different size threads. For work I use one of these tools .. same one, but I bought it at a refrigeration store with the company credit card. 🤭
Amazon garbage
to remove the access valve stem to vacuum refrigeration systems faster .. this should not be required to check fuel pressure - just get the correct adapter.
Mine did the same thing. Had to cycle the ignition a few times to get it to start quickly. It was also starting to stumble on startup like it was fuel starved. I never bothered to check the fuel pressure on mine, went on the assumption that pump was on the way out.
After replacing the fuel pump both issues are gone. The engine fires up quickly now and doesn't stumble. With the age of these cars even at lower miles the fuel pumps are on borrowed time.
I stopped driving mine for a bit until I got around to replacing the pump. Waiting and paying for a tow home after a car craps out, really sucks! I was fortunate that my trucks fuel pump went out after driving home. It had the same symptoms; it finally gave up and wouldn't start anymore after parking it in my garage.
Looking around the junkyard today, I was looking at a '99 Taurus 24V, which uses the same fuel pressure regulator on the fuel rail as my car.
I noticed that the Taurus had an additional device on the fuel line itself. What is this?
Is it supposed to?
Edit: from what I Googled, the Taurus has a returnless system.
