Stupid question. If I had my auto trans features removed in a tune after a manual swap, I shouldn’t have a check engine light, correct?
That’s what I thought. I’ll have to reach out to my tuner.No those should definitely not be showing up if it was deleted in the tune properly
I’m not gonna drop names, but he’s well known in the MN12 community.Whoever did the tune must have forgot to turn off a few things. When I finished swapping in the T45 I test drove it without a tune. It drove like absolute garbage; was backfiring and bucking really badly. Iirc it was putting out more codes than yours is showing
He’s gonna correct it for me, and I have to report fuel trims and some other things to get it dialed in.
In my boost bypass valve there is what looks to be a reducer? Does anyone know what it’s for? I took it out and it doesn’t seem to make a difference.
I had to do the same thing. Rent the tool to turn the caliper piston in to replace the OEM pads.Are the factory rear brake calipers a screw in type piston? My ratcheting caliper tool isn't doing jack...
Found it, they are. Another tool I need to rent or buy
I have those cubes. They were a PITA to use and did not fit very well for the rear as I recall. I rented the proper tool and it worked like a champ. The cubes work fine on the fronts. The rears were pretty stiff this time around.I use the cube tool on a cordless drill. It helps to mount the calipers loosely, without the disk, or remove the cables for the parking brake.
Exactly!I used to use the magic cube of death until I came across an especially stubborn rear caliper on a Freestyle. The cube kept slipping out of the notches in the piston. Every time it did my knuckles would slam into the caliper bracket. It took forever to fully retract it. I bought one of the screw in tools and it makes life so much easier. If a piston isn't stubborn, the cube, or even a pair of needle nose pliers can work. If/when they are stubborn, the screw in tool makes life much easier.
Is there a good source for determining road construction status/quality? I've been taking alternative routes for months now and I don't want to find out firsthand that they've torn things up even more
