weather stripping
Acrux
Atlanta
1991/92 Thunderbird Sport 5.0 HO J-code
I am trying to find a replacement for the weather strip that runs along the top of the car just above the door to the trunk we have searched for some that looked correct but they never seemed to fit any help would be appreciated
Does it look like this? I bought a 15m roll off ebay. Search for T-moulding. I haven't installed mine yet. Mine came with 2-sided tape but I may use 3m weatherstriping glue. 20240529_214843.jpg
Weatherstrip? There's a moulding up there, and depending on year it is different. What year and model are you working on? TBSC shop may have these
I would first get the exact name of the molding then search for it. You can start with RockAuto, but I bet some online place will have it, and the exact fit too. Good luck!
I have the 91/92 J-code but the molding or weather seal is coming off
I have the 91/92 J-code but the molding or weather seal is coming off and where is the TBSC shop on this site?
The problem with the weatherstripping over the roof/pillars on thunderbirds is it isn’t technically considered “weatherstripping” but a part of the trim bonded to the aluminum trim pieces there. There have been discovered substitutions to the weatherstripping across the top of the windshield and back glass but as far as I know the pieces that go along the sides is still something you need to obtain in good used condition unless I’m out of the Tbird loop of things.
The "T" trim goes where there is a gap between aluminum top nad quarter panel. For what it's worth, it is extremely soft and pliable (cheap too). I haven't tried it but i think it may work between the cowl and windshield.
Acrux,
Is this drawing of the stuff you are looking for? (I snagged this drawing off the old site a few years ago) If you're not finding the stuff you're looking for in the aftermarket maybe at a car show with a swap meet, like the one in Dalton this weekend (car show in Dalton on June 14-15 2024).
That question about TSBC: https://www.tbscshop.com/.
Jim
Acrux,
Jim
it's not the drip molding but the 14/15 mm wide strip that is between the wider drip molding and the rear side window running from the door to the trunk these are the pictures of what I am talking about
Resurrecting an older post.... did you (Acrux) ever find the trim you were looking for? I have plenty of trim pieces where these have started to come off. I have found that if they have just separated and will move without breaking, that you can use contact cement to fix them back in place.
Also, for trim pieces where the coating has cracked, I have been using Plasti-dip in a spray can to recoat them. I've done a couple of pieces but haven't yet installed them. I just replaced a back glass and I'll be installing the resprayed trim shortly to test for longevity...
