- North Ridgeville, OH
For you junkyard crawlers out there, please keep an eye out for a few things I could use! None of these are critical, but I'm OCD, so......
97-98 driver's side heated mirror glass
No need to spend the time/effort trying to get the whole mirror housing off the door. The mirror glass just "pops off" the motorized base. Push the inside of the mirror in so the left side protrudes from the housing a little, then just pry it away from the housing. It will pop right off with a little effort. See the attached image for details.
Mine was originally equipped with a heated and auto-dimming mirror but the PO swapped it out for a non-heated, non-dimming mirror (presumably because the auto-dim fluid got dark), and I could really use the defrost!
Another option I am willing to consider is a trade+cash for my non-dimming, non-heated mirror if anyone who is driving one of these doesn't need the heat function.97-98 driver's side mirror puddle lamp assembly
I cut mine open to try and fix intermittent LEDs for the turn signal, but the circuit board was pretty damaged and the LEDs were rusting away.- 98 Charcoal Gray steering wheel
Mine is in decent shape, but if there's a nicer example out there, I wouldn't mind having one. This is a 98 specific color; in 97 they were black. If you happen across one of the super-rare collector's edition Marks, I would be interested in seeing how that might look. Who knows.... - 98 Charcoal Gray driver's seat trim
Mine has a couple busted mounts that no amount of epoxy has been able to (consistently) fix. - 98 Charcoal Gray fuse box cover
I still have mine but one of the tabs that holds it in place snapped off. As such, it spends its time in the seat-back storage pouch instead of covering up the fuse box... - EVAP tray brace
This is the 4' long or so V-shaped cradle that goes under the spare tire well that the EVAP tray screws to. Glove box
The tabs that keep it from falling to the floor snapped off on mine. Color is inconsequential as the front piece from mine can be transplanted over.PWM bracket
Whatever bracket holds the blower motor controller in place is nowhere to be found on my car. I'd prefer to secure it in place to keep the harness from shorting out (again).Spare HID bulb
Mine work fine, but if you happen across one I'd feel better about having a spare. Needs to be functional/tested.
