XR7-4.6’s amateur tuning thread
XR7-4.6
Administrator
Staff member
Roselle, IL
    1994 Cougar XR7 DOHC TR3650
    Ok guys I need serious spoon feeding, tuning has never been my strongsuit but I generally learn enough to be dangerous with some direction if it’s explained to me like I’m a toddler. I’ve been datalogging and “tuning”( guessing and checking) to tame this condition but this is the best I got it and it’s still taking manual intervention to keep it from stalling after a very mild rev. It actually idles pretty good once it’s stabilized and in my datalog of this event the ISC duty cycle hovered around .35-.38ish.
    This makes me think I should be focusing on Dashpot but I’m having an extremely difficult understanding it even with SCTs help sections and forum input (which has become incredibly limited by SCTs nuking of the Pro racer forum, EECtuning being down and Decipha’s site/forum speaking a completely different language from SCT).
    Anyway, you tell me, in this vid I saved it from stalling every time it dipped to near 500rpm and at some point you can see how it stabilizes to the commanded 750 rpm. Even just a hint on what to log and what to mess with and what not to mess with in PRP would be helpful. Right now I’m in over my head
    Log ISC_Integrator. It will tell you how much to add/remove from your idle airflow table to help dial in the idle from the IAC perspective.
    Yep I missed that one! What's your thoughts on the Duty cycle though? I had been reading to shoot for like .15-.25 where mine at idle is pretty consistently at .38ish.
    A mechanical dashpot is a damper like a shock, but near the end of travel, the piston lands on a trapped air cushion, that leaks off slowly, letting the piston hit end of travel. You seem not to arrest the rate of drop, as rpm's bottom out.
    I honestly hadn't read much about it. You could open up the throttle blades a tad if you want to lower it, but I'd probably leave it alone unless there are other symptoms after dialing in the idle airflow.
    The rationale as I understand it in lowering the duty cycle is the ISC is less likely to surge down to the point it stalls as seen after I rev it up and let the rpm’s fall, and this should be done beforehand. I did a quick log a few hours ago and while the integrator is definitely not on target it’s not quite as off, but the absolute lowest the duty cycle went was .37 with a high of .59(which was probably when it was warming up commanding a higher idle).
    I’m supposed to apply the data from the integrator to the ISC neutral/drive idle air sections in PRP, correct?
    I understand it’s function and it’s mechanical equivalent but not so much on the digital end of things.
    Yeah, add or subtract the ISC integrator value from the airflow #/min in the corresponding cell of the idle air table.
    I don't know if drive idle air means anything with a manual, I'd probably just modify both to be safe all the same.
    Depending on how "radical" your cams are considered, it may be worth looking into a slightly higher idle RPM. Mine aren't particularly lopey but I settled on the idle at 800 (factory, ironically) after trying 700 and 750.
    isc duty cycle is the iac pwm duty cycle; it's not a stepper, but a solenoid. those dips are where it's almost dying.
    I second the higher idle rpm. That's even pretty standard with a carb setup and cams. Otherwise your fighting the overlap too much.
    I’m certainly open to increasing the idle speed as a last resort but if not for the transitions it actually idles really happy at 750 with no surge unless it’s induced by me
    I mean, it's sounds pretty damn good most of the time...
    Here’s the actual video of the screenshot I took from it this morning. It maintains rpm pretty much as good as the old cams did on this motor. I even clicked on AC and it didn’t upset it.
    We’ll see tomorrow, I’m created a tune with a static ISC table and ignition timing locked to 15° like a spout plug and will unplug the TPS to try to get the duty cycle down with the set screw, then tweak the integrator. Hopefully that helps, if not I’m moving on to dashpot after
    So I got the integrator to .00, also clipped the lowest idle timing to 15°. Definite improvement, not yet a solution as it still overshoots when the revs fall but it stabilizes substantially better, I think I’m on the right track. IMG_6770.jpeg
    Might try upping the idle timing again to 20° and see what that alone does before I try getting that duty cycle down
    Not as intricate as you are getting, but when I cammed the red car and ran into this issue all I did was set a higher target idle. Fixed it
    Just for shits I upped my idle to 800 via the optional parameters I put in my Xcal and it does indeed not stall when I rev it and take my foot completely off the throttle… but only just, it still nosedives to like 600rpm first and then surges a few times to the 800rpm idle, so I don’t consider it so much as a solution as much as a band aid. I mean my rationale is if it can idle as stable as it does at 750 but get so upset at finding that idle in the transition the tune needs more work. I’d keep this as a temporary solution but to make it drivable enough to take it to a local dyno who can fix it for me
    Mine is set to 850. And yeah if I'm free reving while it's cold it'll do that too, but when it's warm it doesn't.
    Much progress! Swapped the throttle screw for a bolt and a jam nut yesterday but and got to work on lowering the duty cycle using it. Got it down to .20-.25 which is right about in the sweet spot, may adjust further after I redo the idle air integrator which is now way off; but check this out drops right back to idle without any hind of stalling. Still surges up a bit after but I think that’s the integrator being off
    Figured I’d update and rename this thread since I’ll probably be begging for spoon feeding all season 😆. I caught a miserable cold last weekend and pretty much halted any car activity dead for the last 7 days(not that it matters, half the parts I ordered for the exhaust were wrong), but now that I’m feeling mostly better I picked up where I left off getting it drivable.
    So here’s where I’m at, it is reliably drivable, not absolutely perfect but I no longer need to heel/toe the brake/accelerator coming to stops. I also completely eliminated surge at idle (… warmed up, I need to double check cold in the morning), ISC duty cycle at idle at 752rpm is .19 and ISC integrator is 0.00x after much trial and error, which is right on the money. Idles smooth. I can rev it up and let go of the throttle and the absolute lowest it dipped in my logs from that was 640 but it immediately finds its 752ish commanded without surge from there… However… it only behaves so nicely in forced open loop. Closed loop it’s bouncing all over the place without my manual intervention of the throttle to stabilize things. I have read that OL at idle is a fairly common fix with moderate-high overlap cams but my current struggle is I just cannot get it to go OL selectively, eg by RPM or the decel table as I’ve seen suggested, only zeroing the ECT table works which means all the time. I mean what am I doing wrong now?
    I’m not opposed to just leaving it in open loop at all times, but there’s got to be something I’m missing?
    I've heard of that being necessary with extreme cams, but iirc yours were not that extreme. I personally would talk to don, and get his opinion; I'd have no problem offering to pay him for a couple of hours of his time. You're in territory well beyond my help. You're in 'pro' territory, imho. Possibly you could datalog some things, and he can figure it out.
    Is it crabby in CL at idle at all times, or is it when cold or under other conditions?
    There are some tune tweaks required when going to long tubes - mostly an increased delay timer before switching to CL after starting to allow more time for the exhaust (and O2s) to warm up, as well as the O2 transport delay. Our engines don't move a lot of air at idle, and it can take a long time to heat up the exhaust and O2s to the point where they can provide reliable feedback to the PCM for fueling adjustments.
    I increased both of mine but I need to up it even more as occasionally it will dip down to like 500ish RPM for a few seconds before it recovers right when it switches.
    I don’t have the headers on yet, I’ve been trying to get it to behave in between so I can let it heat cycle without issues after I get the headers on. But that’s good to know as I knew I had to tweak something to account for the O2s position.
    It’s pretty consistent through closed loop, it idles very good at the commanded idle but it has trouble finding it after the throttle is released. Open loop no problem.
    I should mention I also made some headway reducing the Idle Spark Gain down again to .5
    Some more observations; I tried lowering the idle spark gain down to .25 and then 0 just to see how it behaves and I found it idles very well and logging spark advance it basically just goes straight off the borderline knock table without any modifiers added, however just as having it set at stock 1.00 or .75 seems to make overcorrections in spark, reducing it to little to nothing makes it more prone to stall from a rev as it doesn't use spark to correct at all, so for now .50 gain seems to be the sweet spot.
    Most interestingly is it still is happiest in open loop. I tried closed loop, closed loop with adaptive disabled and open loop while trying all these spark gain tweaks applied(basically 9-10 flashes) and it’s still happiest where I left off with it on Sunday.
    Overall I feel like I’m on to something with spark though, when I had the gain set at zero the advance in the logs was straight from the borderline table at 18° IIRC. One of the first things I did when I started working on this was clip idle spark at a minimum of 15° which helped immensely, I tried going further to 20° but that seemed to make it prone to stalling again, but that was before I started messing with the gain setting, so that might be my next avenue.
    Stupid question, but are you using an adjustable PCM or even have a PCM in your car? Cause I wish I could override the dang PCM on my car.
    It’s a stock 97 PCM with SCT pro racer software.
    The SCT software overrides stock settings, but no PCM at all means carb+distributor lol
    That is what I was thinking cause I saw that mentioned in a show a while back that the mechanics debated about using the PCM / EFI or go computerless with carb and distributor.
    Hmmm... yank my intake out, put in a holly 4 barrel with a nice 4 barrel carb... NAAAAAHHHH.... what a PITA to have to manage everything else the PCM monitors and controls. That's about what I know. :P
    I mentioned it in the what did you do thread but I should put it here for posterity, as it’s relevant and it’s still a work in progress.
    So basically I’ve done and learned a few things today. First I gave up trying to get this thing to idle at 750 RPM I can get it to idle there after some careful feathering to cushion the surge but there’s so much overlap there’s basically no chance of it ever being happy there in closed loop so I raised it to 850RPM… luckily it still audibly chops.
    I did the same as before, set it to the new desired idle, set the whole ISC transfer function to .15(last time I did .19 but I’ll get to that in a sec) and adjusted the throttle stop screw to get the RPM to match the desired idle RPM. It idles fantastic! Minimal surge, no stalling, even idle vacuum is higher(not great but 15in/hg vs 12)
    What I learned, minimum ISC is actually .199219. I set it to .15 and in this screenshot you can see that’s the lowest it got.
    … but progress! The car’s happy
