Especially the 93 with black interior is exceptionally clean. Need anything, please send a personal message asap. No, I won't get you the drive shaft.
Those are one thing I always grab when I see them.
Yeah, those wiper arms are desired.
MN12s and FN10s use the same cowl/windshield so even though they appear different they are a direct fit.
I've never used those keys, me and 5 of my buddies all run these arms, never an issue, look better and seem to actually perform better as well...
Mine doesn’t have those keys from the factory
Marks also have a parked position that the MN12s don't - when off they sit in about the same place the parked MN12 wipers sit but when they're on they rest a few inches above the parked position for a shorter, faster sweep across the windshield.
Those Ebony seat belts are a must-have for a 94+ MN12 black interior swap. It may be worth grabbing those, the outer-most vent assemblies (the curved ones), and the visors if they are in good shape.
How faded is the carpet?
Interesting! Wonder how that works mechanically.
I hear you, but...
I wonder if they need to be installed without the tiny black plastic keys.
The Mark arms are angled differently. They point up from the anchor point, whereas MN12 go straight to the right, then up. I wonder if the small indent on the hub, where the black plastic key goes into, is positioned differently (?).
The transmission looks largely the same. The magic is in an extra piece on the wiper motor which shifts the armature slightly to park or unpark the arms.Anyone?
I mean, in the MN12, my understanding is the motor only turns in one direction, while the wiper "transmission"/regulator produces the back/forth motion.
Assuming the wiper transmission in the Mark is the same, does that mean that the Mark wiper motor rotates back/forth, thereby not descending the wipers all the way into the parking position?
