4.6 4v
Little Ice-Cable
Indiana
1996 Thunderbird 4.6L v8 SOHC
As Grog will atest to those engines are usually still in factory tolerance at 300k miles or more. So 150k is nothing to be concerned about other than transmission remaining life.
I wouldn’t worry about the mileage, assuming it has been maintained. Before swapping it in, I would pull the pan and check a couple rod and main bearings, and maybe the timing chains and guides, and as long as those aren’t damaged, it should be fine. Even if the engine was damaged, it’s probably still worth it for all the miscellaneous parts you’ll need for the swap, and you could always either rebuild it, or buy another used engine.
I bought a 97 mark motor for a swap. Based on that engine, I would consider it new at 150k Things to consider are:
.B heads won't clear a hood, so 2.5" cowl+ more hood work needed.
C heads and a mach/cobra intake will clear with effort; see Matt's build thread for details.
