91 Cougar LS 5.0 Teardown and Build
The reason I asked because it looks like it was never taken off. But I know you stripped the car down to just the frame, but don't recall a pic of the window being gone. When I had my car painted and I took out the side windows, door trim and all that happy crap, i read that it is a real B to remove the window and if it ain't broke, leave it in. I think one of the reasons was the heated glass. When they did tape up the rear window, it had just a few lines of overspray on the rubber trim, but not that noticeable.
Good luck with that rear window trim creation brain storm. I know you'll share what you find that worked.
I didn't remove it as I trashed the windshield getting it out. I had the body shop remove the rear glass, thus no pictures...
Trying to decide if I should paint the metal frame of the dash. I think there was always some rust on it, but not sure. I wouldn't think it would ever become a structural issue. Thoughts?
View attachment 8728View attachment 8729
They’re all like that, even in the sunbelt. It’s just surface rust, if you took a wire wheel to it there wouldn’t even be any pits so no I certainly wouldn’t worry about any structural issues. I painted mine black just because I was bored and I had the dash completely apart to modify the harness
Been slow going on the car the last couple months. Waiting on this or that part, or my indecision. Got some minor stuff done tonight. I'm building a custom sub box and amp rack to go in the spare tire well. In order to have the amp separated from the sub box, but make it look like one cohesive piece, I'm basically covering both with 1/8" mdf. Then also covering the back seat and braces with the same. They turned out decent, and once mounted sub and amp, should look good. I cut the fabric short around the sub hole, so it's much bigger than it looks. I think it's 10 5/8" for a 12"sub.
If anyone can think of a decent mesh to cover the amp, I'd take suggestions. The sub cover looks like this:
Watching another guys rebuild, I noticed how he would clean and spray what he could for rust prevention. You have moisture there. spray it if you can to slow down, stop the rust. I know its inside... but its still rust. IMO
It’s the moisture in the air in this case, it’s the kind of rust people on the west coast think is worth money when it’s on the exterior as “patina” since it never really advances rapidly beyond that stage. You can paint it, which I did with mine, but in terms of longevity it’s not going to rot out. It most likely attained that layer of surface rust in 1991 and hasn’t advanced since
Kind of hi-jacked the stupid question thread, so going further here.
To summarize the conversation, I found the Holley Hi-ram intake that needs a short Holley distributor and they are not compatible with the Ford ECU. So, either spend the money on a Holley sniper or terminator EFI, or switch to an Explorer ECU and harness. This gets rid of the distributor for coils.
@XR7-4.6, I tossed the wiring harness from the parts car, and it was a mess anyway.
If I were to go looking for an Explorer 5.0 harness, would I need a 96-97, or could I go up to 2001? I noticed the later have PATS, which I don't want. It's think I can exclude all of that as I just need the engine harness.
The biggest issue with harnesses is there isn’t really just a harness to throw on and send, they have different bulkhead connectors and conform around the engine compartment differently. You’d need to do a lot of modifying of it. Plus an Explorer EEC is 104 pin, so you’d need the harness that goes to the EEC too which is where a MN12 doner would be an almost drop in. It would actually be easier to modify a 4.6 engine harness to work on the 5.0 than make an Explorer EEC harness work in a MN12
Ok, maybe I missed that, are you saying use the 4.6 harness and ECU? Or 4.6 harness with Exp ECU?
You could use either once you tune it, you just to change the cam sensor type in the software. If you can find the EEC and harnesses from a 96-97 4.6 that would be the best
If you have to go find one, I'd recommend a 96 cougar mbe2; I've run 3 of them with no failures; avoid fte1's they fail a bunch.
The code is on a sticker pass side,under the rubber hood seal. And on the eec, but underhood is easier
Final test fit done. Box is now sealed, it ended up at right around 1 cubic foot which is perfect for the 12" Alpine sub I choose. Matching amp will be under the square opening, with screen covering that so that nothing falls in. Ordered the amp power wiring tonight for sub amp and 4 main speaker amp.
Does anyone have a great power distribution system they like? Concerned with amount of space in the box. I do plan to do a kill switch so I'm nhra legal as well.
Ordered a bunch of goodies this last weekend, and they showed up today. The more impressive box is coming tomorrow. My bank account is much less impressive than this time last week..... 1000001108.jpg
And as I was waiting for all of this find out my engine will be ready for pick-up on Saturday!!!
Ditch the MSD stuff! The factory ignition system is more capable than you will ever need, and those MSD boxes always cause weird problems. MSD=My Spark Disappeared!
I know. I'm going Holley terminator for the EFI, in order to run the intake I want/need. That necessitates a super short distributor which needs the MSD box.
It's not what I was planning, as I wanted to run the stock ECU and wiring, but by the time I buy a mass air big enough for what I want, I would have had nearly as much invested for 30-50 HP less. Plus now I can easily have it Dyno tuned for both 91 and E85.
A couple questions: Is the fuel return and vent line on our cars 5/16"?
And I don't that I did save the brake lines from my donor car, which was a 1995 Cougar. It looks like I get a non-ABS master cylinder that will match the 2 port design to fit in my 1" booster. That was a drum brake car, and I'm converting to disk, so What I'm wondering is if that prop valve would need changed to? Otherwise I'll cut the lines and bend new up to the 4 pot unit and put in 2 prop valves for the rear.
Mad rush to get everything in/on the car before I hopefully get it to my nephews shop this weekend. He has a lift so installing the motor, trans, and k member together from the bottom will be much easier.
Can anyone tell me if the 3 electrical plugs that come thru the passenger firewall with the ECU harness are the same on V6 and V8 cars? How about 4.6 vs 5.0 cars? I'd like to keep my engine harness intact and use another to make my gauges work with the Holley EFI.
View attachment 11296View attachment 11297
The plugs are year range specific, 94-95 4.6 will interchange with 3.8 but not say 94 to 96. Presumably that’s the case with older models. The basic circuits in the connectors are actually mostly the same so it is possible to retrofit(I modified a 96 EEC harness to work with my 94-95 dash harness)
Makes sense. Unfortunately the shop manual doesn't go into that much detail. I just hate the idea of tearing up my nicely refurbished harness for a handful of wires. Thanks!
An EVTM is what you want for wiring guidance, shop manuals are procedural for troubleshooting, EVTMs on the other hand are literally a blueprint for your cars wiring.
Got a bit more on the interior in yesterday and worked a bit on my kill switch. Today, I got everything loaded and the car taken to the shop. My truck was feeling it a bit!.1000001161.jpg1000001164.jpg1000001166.jpg
After all of that, we finally got to year into it a bit. The subframe is out and ready for a bit of prep before the first run of the install. I anticipate it going in a couple times before it lands home.1000001168.jpg1000001169.jpg
IMG_20250425_163216757.jpgIMG_20250425_163228467.jpgIMG_20250425_164304609.jpgIMG_20250425_164310065.jpg
Created my cart, mated the trans to the motor, added a couple accessories and lowered the body over it for a test fit. I think I'll want to lower the K member. It will be close with my hood.
What is the best to shim the K member down? Rectangular aluminum tubing?
View attachment 11567View attachment 11568View attachment 11569View attachment 11570
Don't use tubing. I used T6061 aluminum blocks....
I dont think its going to clear the stock hood with them either lol
I also used the solid aluminum bar. I think I used 1x1.5”, but I’ll have to check. I did 4 pieces, each with 2 bolts going through. I think you have to separate them like that for clearance around the sway bar.
