JacobM03
2nd Gear Poster
I installed an AJE K member in my 92 tbird with the 5.0 and it seemed like it raised the engine quite a bit, I took some mesurements from the frame where the k member sits and the mounts on the engine and it mesures about 2 inches taller than the stock K member!
I wanted to check it out as right now im pretty sure the hood won’t clear my distributor cap nor my 95 mustang alternator upgrade!
I tried contacting AJE about this and of course they aren’t emailing back.
So what should I do about this? Should I space down the k member 2 whole inches? Would this make a big change in the suspension geometry and handling and steering? Right now the lower and upper A arms are about equal.
I have also contacted someone that had the same issue but with a stockish 4.6 that they had to change the stock hood to clear the engine.
