OdometerStuckTVCableBroke
I have a 1992 Ford Thunderbird with the 5.0 that I paid $500. I noticed that after a while driving, and after a fuel pump change (which is also going bad), that it was shifting late. I dropped the pan, and the fluid was pink from the previous owners. I put the new filter and fluid in, and drove it. For a bit, it drove fine but then it started shifting late again, and after sitting for a bit, it wouldn't go into gear unless the engine was up to around 1800-2200RPMS. Here's the TV cable exactly the way I found it when I popped the hood. I've put maybe 300 miles on it over the course of me owning it. I'm new to AOD transmissions, and I can't figure it out because everything looks normal (minus the ziptie).
