Electrical question.
On my '95 4.6 T-bird, I cleaned out the EGR tube to pass the state emission inspection seven years ago. I didn't bother fixing the cause, just addressed what was needed to satisfy the PCM. Of course eventually the P0402 came back, but I'm not going to go through that EGR tube hassle again as now it's emission exempt. Covering the MIL with electrical tape is too messy so I pulled the instrument cluster and removed the check engine light bulb.
Here's the problem, now the interior courtesy lights stay on with car shut off. Interesting if it was designed that way to discourage people from pulling the cluster bulb. Simple solution will be to pull fuse #6 for the courtesy lights and a few accessories I don't use. Pulling the bulbs would be too much work because the door key lamps are on that circuit. Or paint the MIL bulb black and put it back in the cluster.
Or does anyone think removing the cluster bulb and the courtesy lights staying on are unrelated?
Thanks
Thanks
