None of the timing cover bolt holes are “wet”(actually I can’t think of any in the mod motors that are)
That’s super weird, my pops and I literally took of the charger bracket and left the 2 bolts out and had 0 leaks, out the bracket back on and the leak came back. Pretty frustrated at this point.None of the timing cover bolt holes are “wet”(actually I can’t think of any in the mod motors that are)
It’s leaking engine oil from the timing cover in that general area. It’s the same leak from prior rebuild that killed my engineWhat is leaking? Oil, coolant, something else?
if so we’re both on crack hahaI thought there was a bolt that would leak but the explorer front cover had that bolt. am I on crack?
Nahh it’s the opposite side of the cover.It’s could be a PS pump leak if it’s in that area,
It’s a steady leak, not GUSHING but it definitely don’t stop. And behind the cover is just the chain and guides.What is immediately behind the cover? Just the chains and guides?
Is it the correct bolt to be using there? Should it be shorter or longer, perhaps?
Is the cover metal fatigued and installing the bolt separate / crack the metal enough?
How fast / slow is the leak?
What do you mean by worm holes??Front covers get holes worn in them from the belt tensioner. move it and look behind pullies.this is inside the front cover:
This is an 04 towncar motor.
How do you get wormholes from HOLES WORN IN THE FRONT COVER. Seriously. It's not that rare, if you leave the idler long enough.
And I'm the stoner here, lol.
Dirty bird here, havnt left this spot in MONTHS.
Anyways, I put the front bumper together and tightened up the control arms today. In the oicture in point at the point in the hood where the plenum is LITERALLY pushing up against the hood. I REALLY don’t want to buy a higher hood. Kinda jut wanna cut a small hole and put a scoop on it.
Would that affect the handling in anyway? Kinda seems like it’ll change the camber curves a smidge. I’m not appointed to it. I already have some aluminum wheels n me I could use.Or get a couple 1/2” x 2” T6061 aluminum blocks and put them between the K member and frame rails to lower the engine, that’s what I did to get my DOHC to clear the stock hood.
For sure thanks for the tip, I definitely didn’t want to cut the hood. So 1/2” thick by 2” long, I know the mounting pads aren’t very big at all. Do you have pictures of yours??At that thickness not detrimentally, I think you’d need 1” or thicker to hurt the geometry
I do need to align it anyways, it currently has a weak alignment from when I dropped the arms. Thank you!It'll change the uca angle a tiny amount, but if you get it aligned after, it will be normal.
The lca is attached to the k, the upper to the body. This loses a tiny amount of the range of the ball joints, similar to lowering springs.
It adjusts out of the allignment.
I see industrial strength zip ties poking out from under the hood so at least your head is in the right place. Can you just cut away some of the bracing on the bottom of the hood or is the interference more severe than that?Dirty bird here, havnt left this spot in MONTHS.
Thanks for the tip, the plenum is DEFINITELY hitting the hood and no bueno.I shimmed mine down 3/4". I ended up having to shim the sway bar down as well, but I plan to look at that again. I think the AJE K member may have had some fault there as well as the backwards upper A arms.
If You're running the analog signal to the xcal, you need to also run the ground from the wideband and the signal twisted together to the xcal input, grounding elsewhere adds shitloads of noise. If you're using a Mac printer cable, get a shielded one.
Niiiiiice!Thanks for the tip, the plenum is DEFINITELY hitting the hood and no bueno.
I finally got the tune decent enough for it to drive a lil bit and idle. Still a little lean but I can’t seem to get the damn AEM gauge and sct to data log correctly. So just tuning by looking at the AD counts and AFR.
Niiiiiice!
I’ve never been a fan of AEM gauges, I’ve always like Autometer, but they are expensive.
